Windows 10: Xbox one wireless adapter's sound cuts off in "power saver" power plan.
Discus and support Xbox one wireless adapter's sound cuts off in "power saver" power plan. in Windows 10 Performance & Maintenance to solve the problem; So im watching a video or reproducing sound on my pc, then for whatever reason I clic Stop, or Pause. 30 seconds later, I can't resume playback. The... Discussion in 'Windows 10 Performance & Maintenance' started by Rodrigo_bko, Nov 10, 2021.
Xbox one wireless adapter's sound cuts off in "power saver" power plan. - Similar Threads - Xbox wireless adapter's
Xbox Wireless Adapter, controller powers off as soon as it connects to the adapter
in Windows 10 GamingXbox Wireless Adapter, controller powers off as soon as it connects to the adapter: Xbox Support said I should contact PC support for this topic. I am trying to connect my Xbox Series controller to PC using the Xbox Wireless Adapter for Windows 10. I am having an issue where on every power cycle of my PC, I can connect the controller once and it be just... -
in Windows 10 Software and AppsXbox Wireless Adapter, controller powers off as soon as it connects to the adapter: Xbox Support said I should contact PC support for this topic. I am trying to connect my Xbox Series controller to PC using the Xbox Wireless Adapter for Windows 10. I am having an issue where on every power cycle of my PC, I can connect the controller once and it be just... -
Power plan changing to 'Power saver' automatically
in Windows 10 Software and AppsPower plan changing to 'Power saver' automatically: Hi,I recently came across a problem with my performance on my laptop. In the end, I discovered that the power plans on my laptop Windows 10 are messed up real good.On every start or restart, every time I plug and unplug the charger, the Windows power plan is set to 'Power... -
in Windows 10 GamingPower plan changing to 'Power saver' automatically: Hi,I recently came across a problem with my performance on my laptop. In the end, I discovered that the power plans on my laptop Windows 10 are messed up real good.On every start or restart, every time I plug and unplug the charger, the Windows power plan is set to 'Power... -
in Windows 10 CustomizationPower plan changing to 'Power saver' automatically: Hi,I recently came across a problem with my performance on my laptop. In the end, I discovered that the power plans on my laptop Windows 10 are messed up real good.On every start or restart, every time I plug and unplug the charger, the Windows power plan is set to 'Power... -
in Windows 10 GamingXbox one wireless adapter's sound cuts off in "power saver" power plan.: So im watching a video or reproducing sound on my pc, then for whatever reason I clic Stop, or Pause. 30 seconds later, I can't resume playback. The video keeps paused and my sound devices crashes. The only way to solve this is unpluging the 3,5 jack from the controller, so... -
in Windows 10 Software and AppsXbox one wireless adapter's sound cuts off in "power saver" power plan.: So im watching a video or reproducing sound on my pc, then for whatever reason I clic Stop, or Pause. 30 seconds later, I can't resume playback. The video keeps paused and my sound devices crashes. The only way to solve this is unpluging the 3,5 jack from the controller, so... -
Power Plan keeps on shifting to Power Saver Every time
in Windows 10 BSOD Crashes and DebuggingPower Plan keeps on shifting to Power Saver Every time: In my Asus TUF FX505DY, whenever I turn on the laptop or put it on a charge or wake it up after sleep, the power plan changes to Power Saver. I have tried everything from cmd to registry to Clean Boot to even reinstalling windows, but none of them worked. I updated Windows,... -
Laptop balanced power plan or power saver
in Windows 10 BSOD Crashes and DebuggingLaptop balanced power plan or power saver: My laptop vents has no dust and foreign matters, also i have cooling pad. But when cpu going to 100% caused by update, maintenance, etc, it can hurt my 6 years laptop. Since the temperature can be mesured in 3rd patry app called core temp it rise about 75% when heavy load,...
