Windows 10: 1. battery not charging .help apps dont work .Has anyone successfully fixed this problem.
Discus and support 1. battery not charging .help apps dont work .Has anyone successfully fixed this problem. in Windows 10 Drivers and Hardware to solve the problem; Also when I select phone icon in messenger I am given a dialogue box directing me to settings but nothing seems appropriate any suggestions... Discussion in 'Windows 10 Drivers and Hardware' started by SuziGlanz, Sep 30, 2018.
1. battery not charging .help apps dont work .Has anyone successfully fixed this problem. - Similar Threads - battery charging help
Battery charging problem
in Windows 10 GamingBattery charging problem: My laptop Acer Aspire 5742z-4512 battery is not charging it show a messsage saying 0% available plugged in charging.Just a year ago i had bought this new battery for my laptop and now within 1 year of using this problem has arised..I tried uninstalling the drivers and... -
in Windows 10 Software and AppsBattery charging problem: My laptop Acer Aspire 5742z-4512 battery is not charging it show a messsage saying 0% available plugged in charging.Just a year ago i had bought this new battery for my laptop and now within 1 year of using this problem has arised..I tried uninstalling the drivers and... -
Will Windows crash? Has anyone done this successfully?
in Windows 10 Installation and UpgradeWill Windows crash? Has anyone done this successfully?: https://www.thewindowsclub.com/how-to-change-legacy-to-uefi-without-reinstalling-windows-10I wanted to convert from legacy to uefi. My PC repair guy changed it from uefi to legacy while repairing my pc and now I want it to be uefi. Will this work? Or will my Windows crash?... -
Battery charging Problem
in Windows 10 Drivers and HardwareBattery charging Problem: I am plugging my laptop and it is showing charging but does not get charged over more than 40-50%. Someone please help. Facing the issue from last month. https://answers.microsoft.com/en-us/windows/forum/all/battery-charging-problem/1d581f76-479c-4d36-988e-4b0e646014ca -
in Windows 10 Performance & MaintenanceBattery charging problem: When i charge my laptop while it is in 2% or less "battery is low" pop ups every 20 or 30 seconds until it goes the 10%..and also whiel i play game the charing led indicator blinks and the game starts to hang whenever it blinks....... -
Has there been a successful fix for the problem detailed below?
in Windows 10 Performance & MaintenanceHas there been a successful fix for the problem detailed below?: I read the following thread but didn't see anything that indicated a fix. Has a fix or workaround been established? I use Windows 10 Pro on HP Zbook 17 x64 intel i7-4700. I've done everything listed in the thread with no apparent effect. In fact, the system went into sleep... -
my battery is not charging can anyone help
in Windows 10 Performance & Maintenancemy battery is not charging can anyone help: My battery is currently sitting at 8% and is plugged in. If I unplug it from the mains, and then replug in it starts to charge then after 10 secs stops charging. Can any one help... -
Problem charging the battery
in Windows 10 Drivers and HardwareProblem charging the battery: when connect hp laptop charger to pc, start charging some minutes then stop charging >. This process is repeated as long as the charger is connected to the device. I removed the battery from the device and connected the charger and found that there was no problem with the... -
Battery "Plugged in, not charging" - has a workable fix been found
in Windows 10 Drivers and HardwareBattery "Plugged in, not charging" - has a workable fix been found: I have tried the uninstall drive/auto reinstall etc. Nothing works. It is not the battery or the cord, or the transformer - I replaced them all, and found the problem still exists....
