Windows 10: 3.5 mm headphones not working in either front or rear slot, Realtek audio not installing...
Discus and support 3.5 mm headphones not working in either front or rear slot, Realtek audio not installing... in Windows 10 Drivers and Hardware to solve the problem; My 3.5 mm headphones do not work what so ever in either the front or rear slot, I've tried them in another computer and they work and are picked up... Discussion in 'Windows 10 Drivers and Hardware' started by David Demirev, May 22, 2025.
3.5 mm headphones not working in either front or rear slot, Realtek audio not installing... - Similar Threads - headphones working either
in Windows 10 Gaming3.5 mm headphones not working in either front or rear slot, Realtek audio not installing...: My 3.5 mm headphones do not work what so ever in either the front or rear slot, I've tried them in another computer and they work and are picked up fine. When checking sound devices they aren't even registering as a disabled device, when I check device manager > sound and... -
in Windows 10 Software and Apps3.5 mm headphones not working in either front or rear slot, Realtek audio not installing...: My 3.5 mm headphones do not work what so ever in either the front or rear slot, I've tried them in another computer and they work and are picked up fine. When checking sound devices they aren't even registering as a disabled device, when I check device manager > sound and... -
Latest driver for Realtek USB Audio Driver Front and Rear!?
in Windows 10 GamingLatest driver for Realtek USB Audio Driver Front and Rear!?: Hi hi!I am using right now this "audio" driver for my pc windows 11 pro... Realtek Semiconductor Corp.2024-05-026.3.9600.2386Microsoft Windows Hardware Compatibility PublisherThe problem i have right now is... note: my speakers works just fine! ...that i can't use any... -
in Windows 10 Software and AppsLatest driver for Realtek USB Audio Driver Front and Rear!?: Hi hi!I am using right now this "audio" driver for my pc windows 11 pro... Realtek Semiconductor Corp.2024-05-026.3.9600.2386Microsoft Windows Hardware Compatibility PublisherThe problem i have right now is... note: my speakers works just fine! ...that i can't use any... -
Headphones into rear audio jack?
in Windows 10 Drivers and HardwareHeadphones into rear audio jack?: Hello. The headphone input on the front of my PC is broken and I cannot use it anymore. No big deal I thought, I'll plug my headphones into the rear audio jack. Well... that ends up being a massive issue somehow. The back inputs seem to be coded differently, which makes the... -
Unable to separate front and rear audio streams
in Windows 10 Drivers and HardwareUnable to separate front and rear audio streams: Newly build computer with an MSI Z390 Gaming Pro Carbon motherboard. Most up to date versions of Nahimic, Realtek Audio manager and MSI overlay/UI (Realtek driver 6.0.8945.1 & UI version 1.11.217.0) all properly installed. Running Win 10 Pro 1909, build 18363.900. Praying... -
realtek front panel no audio
in Windows 10 Drivers and Hardwarerealtek front panel no audio: so i just make my first pc build. and after everything thing i found out that the front panel audio and mic are not working. first of, even after updating it it did not install realtek hd audio manager. so i found it downloaded it. and after when i did open, it was opened in... -
Option for "Make front and rear separate audio streams" missing with Realtek HD audio
in Windows 10 Drivers and HardwareOption for "Make front and rear separate audio streams" missing with Realtek HD audio: I don't want to keep plugging and unplugging the headphones from the front panel, so I would like to separate the streams as has been possible with earlier Windows and earlier Realtek chipsets. However, MoBo manufacturer doesn't provide control panel and relies on Windows... -
Front and Rear Audio cannot be used simultaneously !
in Windows 10 Drivers and HardwareFront and Rear Audio cannot be used simultaneously !: Hi all, I recently upgraded to Windows 10 from Window 8.1. My desktop has a front audio and mic jack and also a rear audio and mic jack. While watching movies , I connect my rear jack to a large set of speakers and for better voice clarity I plug in earphones onto the front...
