Windows 10: 3.5 mm headphones not working in either front or rear slot, Realtek audio not installing...
Discus and support 3.5 mm headphones not working in either front or rear slot, Realtek audio not installing... in Windows 10 Software and Apps to solve the problem; My 3.5 mm headphones do not work what so ever in either the front or rear slot, I've tried them in another computer and they work and are picked up... Discussion in 'Windows 10 Software and Apps' started by David Demirev, May 22, 2025.
  1. 3.5 mm headphones not working in either front or rear slot, Realtek audio not installing...
    My 3.5 mm headphones do not work what so ever in either the front or rear slot, I've tried them in another computer and they work and are picked up fine. When checking sound devices they aren't even registering as a disabled device, when I check device manager > sound and video game controllers, realtek audio is not there what so ever and when I try to install it through my motherboard manufacturer it doesn't install, and then when i try to install it through windows it causes a BSOD
  2. Headphones do not show up when Realtek is installed
    OK, so this happened to me on my laptop. It wanted to use the realtek drivers no matter what. Let me show you what to do.
    Step 1. Open the start menu and type 'Device Manager' in the search bar. Click on the result.
    Step 2.
    3.5 mm headphones not working in either front or rear slot, Realtek audio not installing... 195247d1531240211t-headphones-do-not-show-up-when-realtek-installed-devmgr.png
    You'll see this window appear.
    Step 3.
    3.5 mm headphones not working in either front or rear slot, Realtek audio not installing... 195248d1531240275t-headphones-do-not-show-up-when-realtek-installed-devmgrsound.png
    Expand the 'Sound , video and game controllers' category.
    Step 4. Find 'Realtek High Definition Audio' in the list, then right click it and select Properties.
    Step 5.
    3.5 mm headphones not working in either front or rear slot, Realtek audio not installing... 195249d1531240441t-headphones-do-not-show-up-when-realtek-installed-devmgrsounddriver.png
    Click on the 'Driver' tab near the top of the window.
    Step 6.
    3.5 mm headphones not working in either front or rear slot, Realtek audio not installing... 195250d1531240560t-headphones-do-not-show-up-when-realtek-installed-driverrollback.png
    Now click on the button that says 'Roll back driver'.
    If the button is dimmed, make sure your Realtek drivers are currently installed.
    Step 6. If you did it correctly, the system should ask you to restart to finish. If it does then you finished the tutorial correctly!
    Once restarted, Open device manager again using step 1. Expand the 'sound, video and game controllers' category again.
    Step 7. If it says 'High Definition Audio Device' then you did it right. Here's a pic for example purposes:
    3.5 mm headphones not working in either front or rear slot, Realtek audio not installing... 195251d1531240808t-headphones-do-not-show-up-when-realtek-installed-highdef.png
    ThatsNiceGuy, May 22, 2025
  3. Latest Realtek HD Audio Driver Version [2]
    I just built a new rig with a ASRock X470 Taichi motherboard and Win 10 64bit 1903. I downloaded the driver from my motherboard's site (Realtek high definition audio driver ver:8668_UAD_WHQL_DTS) and then ran the powershell script to detect the driver type.
    Since I couldn't get more than 1 output, I also tried the latest driver in the 1st post (HDA DRIVER VERSION: 6.0.8716.1).
    No matter what is plugged in, I only have 1 playback/output device.
    • I plug my speakers into rear panel = audio plays out the speakers and listed as Speakers (Realtek Audio)
    • I plug my headphones into front panel = audio plays out my headphones and listed as Speakers (Realtek Audio)
    • I plug my headphones into front panel and speakers into rear panel = audio plays out of front panel and listed as Speakers (Realtek Audio)
    I used to be able to switch between front and rear when both were plugged in. Anyone have any suggestions?
    monsterenergy22, May 22, 2025
  4. JOne24 Win User
    Windows 10 Realtek Audio rear analog jacks not working
    I just upgraded to Windows 10 from Windows 8.1, and found I wasn't getting any audio from my speakers. My Realktek HD Audio manager can detect my analog speakers hook-up in the rear panel. I can hear audio from my front panel analog jacks with my regular
    speakers. I tried updating the audio drivers to 6.0.1.7541 from the Realtek site but still could not hear anything from my rear panel analog jacks (the front still work). Changing the frequency also did not work. (edit 8/2/2015) I went into sounds and checked
    properties for speakers/headphones, the default device. (edit 8/7/2015) It lists the front panel l/r jack and the rear panel l/r jack, along withthe other surround sound jacks (l/r rear, center sub, l/r side).
    JOne24, May 22, 2025
  1. 3.5 mm headphones not working in either front or rear slot, Realtek audio not installing... - Similar Threads - headphones working either
  2. 3.5 mm headphones not working in either front or rear slot, Realtek audio not installing...
    3.5 mm headphones not working in either front or rear slot, Realtek audio not installing...: My 3.5 mm headphones do not work what so ever in either the front or rear slot, I've tried them in another computer and they work and are picked up fine. When checking sound devices they aren't even registering as a disabled device, when I check device manager > sound and...
  3. 3.5 mm headphones not working in either front or rear slot, Realtek audio not installing...
  4. Latest driver for Realtek USB Audio Driver Front and Rear!?
    Latest driver for Realtek USB Audio Driver Front and Rear!?: Hi hi!I am using right now this "audio" driver for my pc windows 11 pro... Realtek Semiconductor Corp.2024-05-026.3.9600.2386Microsoft Windows Hardware Compatibility PublisherThe problem i have right now is... note: my speakers works just fine! ...that i can't use any...
  5. Latest driver for Realtek USB Audio Driver Front and Rear!?
  6. Headphones into rear audio jack?
    Headphones into rear audio jack?: Hello. The headphone input on the front of my PC is broken and I cannot use it anymore. No big deal I thought, I'll plug my headphones into the rear audio jack. Well... that ends up being a massive issue somehow. The back inputs seem to be coded differently, which makes the...
  7. Unable to separate front and rear audio streams
    Unable to separate front and rear audio streams: Newly build computer with an MSI Z390 Gaming Pro Carbon motherboard. Most up to date versions of Nahimic, Realtek Audio manager and MSI overlay/UI (Realtek driver 6.0.8945.1 & UI version 1.11.217.0) all properly installed. Running Win 10 Pro 1909, build 18363.900. Praying...
  8. realtek front panel no audio
    realtek front panel no audio: so i just make my first pc build. and after everything thing i found out that the front panel audio and mic are not working. first of, even after updating it it did not install realtek hd audio manager. so i found it downloaded it. and after when i did open, it was opened in...
  9. Option for "Make front and rear separate audio streams" missing with Realtek HD audio
    Option for "Make front and rear separate audio streams" missing with Realtek HD audio: I don't want to keep plugging and unplugging the headphones from the front panel, so I would like to separate the streams as has been possible with earlier Windows and earlier Realtek chipsets. However, MoBo manufacturer doesn't provide control panel and relies on Windows...
  10. Front and Rear Audio cannot be used simultaneously !
    Front and Rear Audio cannot be used simultaneously !: Hi all, I recently upgraded to Windows 10 from Window 8.1. My desktop has a front audio and mic jack and also a rear audio and mic jack. While watching movies , I connect my rear jack to a large set of speakers and for better voice clarity I plug in earphones onto the front...
