Windows 10: Advanced problem with pc hardware **HELP**
Discus and support Advanced problem with pc hardware **HELP** in Windows 10 BSOD Crashes and Debugging to solve the problem; Ive had my pc for 2 years now, its worked fine all this time. 4 days ago, I purchased a new ryzen 5 processor, to replace my older ryzen 3 processor.... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by MercurialMoon, Jan 6, 2019.
Advanced problem with pc hardware **HELP** - Similar Threads - Advanced problem hardware
Hardware error - help diagnosing the problem
in Windows 10 Software and AppsHardware error - help diagnosing the problem: Hello, Can someone help me understand what hardware this error is referring to and why it occurred?DescriptionA problem with your hardware caused Windows to stop working correctly.Problem signatureProblem Event Name: LiveKernelEventCode: 1a1Parameter 1:... -
in Windows 10 GamingHardware error - help diagnosing the problem: Hello, Can someone help me understand what hardware this error is referring to and why it occurred?DescriptionA problem with your hardware caused Windows to stop working correctly.Problem signatureProblem Event Name: LiveKernelEventCode: 1a1Parameter 1:... -
Hardware help?
in Windows 10 Ask InsiderHardware help?: Hello there everyone! so today i was wondering if I can get help on this issue I've come across today? i was doing my daily play on Minecraft until my screen decided to freeze as my computer crashed. i decided to turn it off, but once it was turned back on i came upon a... -
Advanced Startup Problems
in Windows 10 Installation and UpgradeAdvanced Startup Problems: Alright so, i wanna reset my pc from advanced startup so i dont need to use boot device but when i open advanced startup and click troubleshoot it directly goes into advanced options what do i do to fix this?... -
PC hardware problem, Windows and Linux
in Windows 10 Ask InsiderPC hardware problem, Windows and Linux: I am having internet issues with my desktop. I had Windows ten on it and it said that it was connected to the internet but I could not search anything. I tried changing the DNS settings and using an Ethernet cord but nothing worked. I had a thumb drive with pop os on it so I... -
Help problem with pc
in Windows 10 Ask InsiderHelp problem with pc: Hello guys. When i started my pc today i wanted to check task manager but i didnt open i thought it bugged but then i wanted to open other apps but they didnt launch aswell So im trying to reset the pc so it may fix but it then lags and stays on the screen i cant move it or... -
Hardware Problem - Problem Event Name: LiveKernelEvent HELP!!!!!!!!!
in Windows 10 BSOD Crashes and DebuggingHardware Problem - Problem Event Name: LiveKernelEvent HELP!!!!!!!!!: Hi. I am getting a hardware error Description A problem with your hardware caused Windows to stop working correctly. Problem signature Problem Event Name: LiveKernelEvent Code: 117 Parameter 1: ffffe10b63b55050 Parameter 2: fffff8066301077c Parameter 3: 0 Parameter 4: 3e8c... -
PC Freezing Problem , found a hardware error in control panel. Need Help
in Windows 10 BSOD Crashes and DebuggingPC Freezing Problem , found a hardware error in control panel. Need Help: This is happening to me for the 2nd time actually , i would get a small electronic noise , the frame on the screen would just freeze and i would have to restart through the button on the case , this is strictly happening in games , the first time it happened was 4 months ago... -
Advanced Permissions Problem
in User Accounts and Family SafetyAdvanced Permissions Problem: I want to change the Title of a single file in it's Properties > Details Tab > Description line. When I try to make the change by going to the "Remove Properties and Personal Information" link and Apply, I get the message: "You'll Need To Provide Administrator Permission To...
