Windows 10: at 9pm, pc did not fully power on, AORUS Logo RGB light did not turn on but all other RGB...
Discus and support at 9pm, pc did not fully power on, AORUS Logo RGB light did not turn on but all other RGB... in Windows 10 Software and Apps to solve the problem; tonight around 9PM I went to turn the power back on, to the surge protector after watching some tv, all the lights on the pc went on but for that area... Discussion in 'Windows 10 Software and Apps' started by Robs Gaming Pc, May 20, 2024.
  1. at 9pm, pc did not fully power on, AORUS Logo RGB light did not turn on but all other RGB...
    tonight around 9PM I went to turn the power back on, to the surge protector after watching some tv, all the lights on the pc went on but for that area above in the image that I had circled the lights around AORUS did not run on pressing power button on the front panel of the cooler master half 700 evo case, also it seemed to run the RGB lights and the fan, but not the display or go into the bios, it ran for a few minutes then power off again, so I turned off the power switch on the back of the pc, then wait and back on, then pressed the power button again, this time it loaded the bios then win
  2. Wombo Win User
    RGB case lighting & RGB strip not in sync?
    Bought a prefab custom PC that came with case lights and an RGB strip on the bottom of the case, along with a remote. Both sets of lights aren't in sync when I strobe, flash, etc. Other times, I need to hit the power-on button on the remote twice just to get one or the other to turn on.
    Is this a wiring issue? Also, is there a way to control the RGB lights through some sort of software?
    Wombo, May 20, 2024
  3. comcom Win User
    Ram rgb lights question
    Hello, Q1. If the RGB light of the ram (ram settings is default) is not lighted up, can it indicate that the ram is faulty? Can it indicate that the ram is not inserted properly? Q2. Is it true that even if you set RGB of the ram off, during power up (before login to windows) the ram RGB light will be lighted up, then after you login into windows the ram software will then be auto loaded then the RGB light will be off? Q3. Ignoring the price and only considering ease of troubleshooting, would a RGB ram be a better option than a non RGB ram? I assume if the RGB ram (with default settings) is not lighted up means the ram is going to become faulty or not inserted correctly? Or is a RGB ram worse as it might cause confusion in troubleshooting because RGB ram (with default settings) lighted up or not has no meaning on the ram working condition. Thank you
    comcom, May 20, 2024
    NZXT announces HUE 2 family RGB lighting accessories for PC builders
    Source: NZXT announces HUE 2 family of RGB lighting accessories for PC builders - Windows Experience Blog
    Tweet
    Brink, May 20, 2024
  1. at 9pm, pc did not fully power on, AORUS Logo RGB light did not turn on but all other RGB... - Similar Threads - 9pm did fully
  2. My Pc turns on the fans and rgb turns on but the indicator lights don’t turn on and there...
    My Pc turns on the fans and rgb turns on but the indicator lights don’t turn on and there...: My specs are ROG b550f motherboard ryzen 7 5700x 32gb ram and a 3080 https://answers.microsoft.com/en-us/windows/forum/all/my-pc-turns-on-the-fans-and-rgb-turns-on-but-the/64deb452-b10a-4eef-8460-aadf6e1f757d
  3. My Pc turns on the fans and rgb turns on but the indicator lights don’t turn on and there...
  4. at 9pm, pc did not fully power on, AORUS Logo RGB light did not turn on but all other RGB...
    at 9pm, pc did not fully power on, AORUS Logo RGB light did not turn on but all other RGB...: tonight around 9PM I went to turn the power back on, to the surge protector after watching some tv, all the lights on the pc went on but for that area above in the image that I had circled the lights around AORUS did not run on pressing power button on the front panel of the...
  5. at 9pm, pc did not fully power on, AORUS RGB light did run but all other RGB lights DDR5,...
    at 9pm, pc did not fully power on, AORUS RGB light did run but all other RGB lights DDR5,...: tonight around 9PM I went to turn the power back on, to the surge protector after watching some tv, all the lights on the pc went on but for that area above in the image that I had circled the lights around AORUS did not run on pressing power button on the front panel of the...
  6. at 9pm, pc did not fully power on, AORUS RGB light did run but all other RGB lights DDR5,...
  7. No RGB signal. Power will be turned off.
    No RGB signal. Power will be turned off.: I recently packed up my computer and moved into a new location. Upon setting my computer back up, my monitor has refused to connect to my PC. I thought it might be the cable that was the issue but after buying a new cable the problem remained. Both the monitor and the...
  8. No RGB signal. Power will be turned off.
  9. No RGB signal. Power will be turned off.
  10. RGB case lighting & RGB strip not in sync?
    RGB case lighting & RGB strip not in sync?: Bought a prefab custom PC that came with case lights and an RGB strip on the bottom of the case, along with a remote. Both sets of lights aren't in sync when I strobe, flash, etc. Other times, I need to hit the power-on button on the remote twice just to get one or the other...
