Windows 10: Audio device not workinkno audio after recovery stops Everytime
Discus and support Audio device not workinkno audio after recovery stops Everytime in Windows 10 BSOD Crashes and Debugging to solve the problem; I have been having a brain fart.. any and every time I reset my computer ..recovery feature the audio device goes out and after system restore you... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by BrandonOvalle, Apr 14, 2020.
Audio device not workinkno audio after recovery stops Everytime - Similar Threads - Audio device workinkno
Audio stopped working and now it says "No audio device is installed"
in Windows 10 GamingAudio stopped working and now it says "No audio device is installed": I use Astro A50 headset and it just stopped working. It works fine on XBOX, I hear the ding when it turns on, but connected to my PC no audio and when I check settings it says no audio device is installed. I tried updating drivers for astro a50, realtek audio and nothing. I... -
in Windows 10 Software and AppsAudio stopped working and now it says "No audio device is installed": I use Astro A50 headset and it just stopped working. It works fine on XBOX, I hear the ding when it turns on, but connected to my PC no audio and when I check settings it says no audio device is installed. I tried updating drivers for astro a50, realtek audio and nothing. I... -
Audio just stopped working *No Audio Output Device Installed
in Windows 10 GamingAudio just stopped working *No Audio Output Device Installed: Getting desperate :- I've tried everything uninstalling drivers, updating drivers, hard reset, updated BIOS, downgraded from Windows 11 to 10. Nothing has worked. This issue happened to 5 days ago. I have a HP Envy 360 yes I've gone to their website and downloaded drivers... -
in Windows 10 Software and AppsAudio just stopped working *No Audio Output Device Installed: Getting desperate :- I've tried everything uninstalling drivers, updating drivers, hard reset, updated BIOS, downgraded from Windows 11 to 10. Nothing has worked. This issue happened to 5 days ago. I have a HP Envy 360 yes I've gone to their website and downloaded drivers... -
in Windows 10 Drivers and HardwareAudio just stopped working *No Audio Output Device Installed: Getting desperate :- I've tried everything uninstalling drivers, updating drivers, hard reset, updated BIOS, downgraded from Windows 11 to 10. Nothing has worked. This issue happened to 5 days ago. I have a HP Envy 360 yes I've gone to their website and downloaded drivers... -
Everytime Windows Updates installs anything, my audio and video devices stop working with...
in Windows 10 GamingEverytime Windows Updates installs anything, my audio and video devices stop working with...: This has happened at least three times now. after a major Windows Update goes through, playing back video or audio will fail with the error 0x800706beThe previous two times I was able to fix it by deleting all of my audio drivers and manually reinstalling them....but this... -
How to stop audio devices changing
in Windows 10 Drivers and HardwareHow to stop audio devices changing: Is there a way to disable the behaviour of Windows altering what your "default" device is whenever you plug in a new one? If not then what is the actual functionality of the default besides being the currently selected device? Every time I plug in a controller or a webcam... -
Audio Device Randomly Stops Working
in Windows 10 Drivers and HardwareAudio Device Randomly Stops Working: Hello, I use a TV as a monitor, and as of the April update, the audio driver seems to be exceptionally unstable. I have isolated the issue to Windows, by using different devices with the HDMI port on the TV, different cables, and different ports from my PC to the TV.... -
AUdio stopped working - no audio output device is installed
in Windows 10 Drivers and HardwareAUdio stopped working - no audio output device is installed: How do I fix this problem? https://answers.microsoft.com/en-us/windows/forum/all/audio-stopped-working-no-audio-output-device-is/75f55d42-67d6-44f5-9f5e-df2841327b80
