Windows 10: Audio output device problem
Discus and support Audio output device problem in Windows 10 Support to solve the problem; I have my audio output device on my HP laptop set to a Bluetooth wireless device. Every time I boot from shutdown or on restart the computer, the... Discussion in 'Windows 10 Support' started by JAG01, May 17, 2019.
  1. JAG01 Win User
    I have my audio output device on my HP laptop set to a Bluetooth wireless device. Every time I boot from shutdown or on restart the computer, the output resets to the computer's audio device. I have to reset it in Bluetooth and other device settings. How can I stop this? Is there a default setting somewhere?
    JAG01, May 17, 2019
  2. No Audio Output Device is Installed
    You will need to select Windows 8 from the drop down list while installing the driver in compatibility mode.
    I would suggest you to try setting the speaker as default audio output by following the steps below and check if it helps.
    1. Right click on the sound icon on the right bottom corner of the taskbar.
    2. Select "playback devices".
    3. If "speaker" is not set as the default device, highlight it and click "set as default".
    5. Save the changes.
    Let us know the result.
    Wungraileng Vashi, May 17, 2019
  3. fireberd Win User
    No audio output device is installed
    A screenshot of the Device Manager, Sounds section is still needed. Can't really offer a suggestion until I see what is showing there now.
    e.g this is mine It shows AMD which the audio for HDMI, Realtek and Tranzport which is a wireless controller for my recording studio program.
    Audio output device problem [​IMG]
    fireberd, May 17, 2019
  4. Allan Mej Win User
    No Audio Output Device Installed
    Hi Sly,
    It is possible that your audio output device itself is not working. To further assist your concern, kindly answer these following questions:
    • Have you made any changes to your PC prior to the issue?
    • Have you tried using other audio output devices on your PC? If yes, did it work on your PC?
    • What are the troubleshooting methods you've tried so far?
    We'll be looking forward for your reply.
    Regards.
    Allan Mej, May 17, 2019
  1. Audio output device problem - Similar Threads - Audio output device
  2. No audio output device
    No audio output device: When I plug in my headphones Steelseries Arctis 5, all of a sudden all sound goes out and it says that there is no audio output device. The sound comes on for a moment, as if it recognizes it for a few seconds, but that's it, it can't find any output or input devices. When I...
  3. audio output devices
    audio output devices: My smart phone is paired to my laptop but I cannot get the laptop to output audio to my smart phone. https://answers.microsoft.com/en-us/windows/forum/all/audio-output-devices/c8ddc572-e46b-4e33-92ab-baa684f6027b
  4. Audio not detected or "no audio output device installed" problem
    Audio not detected or "no audio output device installed" problem: hello, I am having a problem with my windows 10 PC. I've recently installed the windows 10 version 20H2 and all of a sudden it says that no audio devices are installed. I've tried uninstalling feature updates and quality updates but nothing seems to work. Even my monitor...
  5. audio output device
    audio output device: My surface pro seven suddenly does not have sound. It says there is no audio output driver. I talked to someone at microsoft and they had me uninstall and reinstall updates. I cannot reinstall an audio driver because the device manager list of devices does not even show sound...
  6. audio output device
    audio output device: My laptop has no audio output device installed, can someone help me rectify this problem/ https://answers.microsoft.com/en-us/windows/forum/all/audio-output-device/bf8d0d4c-fc5d-4db5-ad34-f9b69a93ba46
  7. output audio device
    output audio device: my system is showing notification of no audio output device is installed and even no audio sound is audible.. https://answers.microsoft.com/en-us/windows/forum/all/output-audio-device/5b5d3f20-0ab8-4f46-94cb-106a14808e96
  8. A way to solve "No audio device output" problem!
    A way to solve "No audio device output" problem!: I just found a way to solve this problem when the troubleshooting fails. In order to use my method your audio device must be disconnected with your driver, or when you update driver on the device and it returns with null/nill and no found updates. To do this you must manually...
  9. No Audio output device
    No Audio output device: I have a No Audio Issue started about 2 days ago. In my search of the issue on my Surface I found Remote Capture Remote Render info. I've reinstalled Windows 10 but still no audio and possible remote control over my system 118000
  10. No Audio output device
