Windows 10: Audio problem with PS5 controller
Discus and support Audio problem with PS5 controller in Windows 10 Gaming to solve the problem; I have a PS5 controller connected over bluetooth to my pc.If I connect my controller with a cable, this problem is no longer there.Over the course of... Discussion in 'Windows 10 Gaming' started by NicoBuela, Apr 21, 2024.
Audio problem with PS5 controller - Similar Threads - Audio problem PS5
PS5 controller removes headset as audio device
in Windows 10 GamingPS5 controller removes headset as audio device: When I plug in my ps5 controller to my pc, not only does it set it as the default audio device, but it actually removes my headset as an audio device from my pc. I can look at my audio devices, see my headset there, and immediately when I plug the ps5 controller in, my... -
in Windows 10 Software and AppsPS5 controller removes headset as audio device: When I plug in my ps5 controller to my pc, not only does it set it as the default audio device, but it actually removes my headset as an audio device from my pc. I can look at my audio devices, see my headset there, and immediately when I plug the ps5 controller in, my... -
in Windows 10 Software and AppsAudio problem with PS5 controller: I have a PS5 controller connected over bluetooth to my pc.If I connect my controller with a cable, this problem is no longer there.Over the course of using the controller, my bluetooth headphones don't work for 2s and then they come back.It's like the audio is going through... -
PS5 controller problem with PC
in Windows 10 Drivers and HardwarePS5 controller problem with PC: Dear Support!I have a special problem with my PS5 controller. I used to play games with it, the PC recognized it and worked perfectly fine. One day it does not light up, the system does not recognize, the system thinks there is no controller connected, but there is. If I... -
in Windows 10 GamingPS5 controller problem with PC: Dear Support!I have a special problem with my PS5 controller. I used to play games with it, the PC recognized it and worked perfectly fine. One day it does not light up, the system does not recognize, the system thinks there is no controller connected, but there is. If I... -
in Windows 10 Software and AppsPS5 controller problem with PC: Dear Support!I have a special problem with my PS5 controller. I used to play games with it, the PC recognized it and worked perfectly fine. One day it does not light up, the system does not recognize, the system thinks there is no controller connected, but there is. If I... -
in Windows 10 BSOD Crashes and DebuggingPS5 controller problem with PC: Dear Support!I have a special problem with my PS5 controller. I used to play games with it, the PC recognized it and worked perfectly fine. One day it does not light up, the system does not recognize, the system thinks there is no controller connected, but there is. If I... -
Problem with my PS5 controller on PC
in Windows 10 GamingProblem with my PS5 controller on PC: Hello, Here is my problem, I often play with my PS5 controller on my pc and everything works fine I use DS4Windows. But unfortunately since a few days my controller does not connect to my PC when I plug in my controller nothing happens it does not light up in yellow to load... -
in Windows 10 Software and AppsProblem with my PS5 controller on PC: Hello, Here is my problem, I often play with my PS5 controller on my pc and everything works fine I use DS4Windows. But unfortunately since a few days my controller does not connect to my PC when I plug in my controller nothing happens it does not light up in yellow to load...
