Windows 10: audio problems with dual display
Discus and support audio problems with dual display in Windows 10 Customization to solve the problem; i set up a small flatscreen as a second display, I have sound coming from both the built in speakers on my monitor and my tv however the audio sounds... Discussion in 'Windows 10 Customization' started by Christian Williams1, Oct 6, 2022.
audio problems with dual display - Similar Threads - audio problems dual
Dual Display
in Windows 10 GamingDual Display: I am unable to have my personal laptop display properly on 2 displays, 34 inch ultrawide and 25 Inch ultrasharp. They are connected to a dell powered docking station capable of dual display with display port. If I unplug the second display, the ultrawide works just fine. When... -
Dual Display
in Windows 10 Software and AppsDual Display: I am unable to have my personal laptop display properly on 2 displays, 34 inch ultrawide and 25 Inch ultrasharp. They are connected to a dell powered docking station capable of dual display with display port. If I unplug the second display, the ultrawide works just fine. When... -
Problem extending Surface Laptop 4 to dual-displays.
in Windows 10 GamingProblem extending Surface Laptop 4 to dual-displays.: Hello I am trying to extend the display on my Surface Laptop 4 to two external monitors Lenovo Thinkvision / Dell P2417H.I am using a Port Connect Professional Docking Type C Travel 2 X 4K. I am using HDMI inserted into monitors to DP inserted into dock cables to connect... -
in Windows 10 Software and AppsProblem extending Surface Laptop 4 to dual-displays.: Hello I am trying to extend the display on my Surface Laptop 4 to two external monitors Lenovo Thinkvision / Dell P2417H.I am using a Port Connect Professional Docking Type C Travel 2 X 4K. I am using HDMI inserted into monitors to DP inserted into dock cables to connect... -
in Windows 10 Gamingaudio problems with dual display: i set up a small flatscreen as a second display, I have sound coming from both the built in speakers on my monitor and my tv however the audio sounds more like an echo than the two playing at the same time how can i fix this? Ex, sound comes from computer but the sound coming... -
in Windows 10 Software and Appsaudio problems with dual display: i set up a small flatscreen as a second display, I have sound coming from both the built in speakers on my monitor and my tv however the audio sounds more like an echo than the two playing at the same time how can i fix this? Ex, sound comes from computer but the sound coming... -
Dual Displays
in Windows 10 CustomizationDual Displays: Hi... I'm setting up dual displays 1 regular ViewSonic computer monitor -VGA connection / 1 BenQ TV screen - HDMI connection. My trouble is getting the screen resolution sizes to work for both screens. The best I've got so far is the setting for "Duplicate These Displays" /... -
Dual displays
in Windows 10 Drivers and HardwareDual displays: My dual screens have suddenly stopped being separate and now the same images are on both screens. ow do I fix that? https://answers.microsoft.com/en-us/windows/forum/all/dual-displays/53908532-4825-4de0-8c59-cd151be887fe -
Dual display problem
in Windows 10 Drivers and HardwareDual display problem: I have hooked up dual displays on my Dell XPS computer and cannot get the displays to show dual images IE: screen 1 main screen info and screen 2 separate sheet info. If I select extend image, monitor 2 only has background image and no controls. If I select show only on...
