Windows 10: Audo device does not save its settings, Spacial sound AND Bit rate.
Discus and support Audo device does not save its settings, Spacial sound AND Bit rate. in Windows 10 Customization to solve the problem; Every time I restart my PC or every time I unplug or plug in my headset I lose my Audio settings in windows. I like to always have "DTS Headphone:X" as... Discussion in 'Windows 10 Customization' started by MathewArmstrong, Jul 28, 2020.
Audo device does not save its settings, Spacial sound AND Bit rate. - Similar Threads - Audo device does
Windows Soundmixer does not save sound settings
in Windows 10 GamingWindows Soundmixer does not save sound settings: Dear Community,I have a problem with my soundmixer. I am someone who enjoys having the windows system sounds to a very low level. Like 5%. while games and other application should be louder 80%-100%. However, the windows system sounds randomly reset to 100%, causing pain in... -
in Windows 10 Software and AppsWindows Soundmixer does not save sound settings: Dear Community,I have a problem with my soundmixer. I am someone who enjoys having the windows system sounds to a very low level. Like 5%. while games and other application should be louder 80%-100%. However, the windows system sounds randomly reset to 100%, causing pain in... -
Spacial Sound not working
in Windows 10 CustomizationSpacial Sound not working: Hi there! Recently i started to use my HP Elitebook 2560p laptop with Windows 10 Pro trough a USB Hard Drive since my laptop's SATA port became faulty. All the drivers are installed and are running correcty, except one who's "Unknown Device". Whatever, that doesn't affect my... -
Spacial Sound Issue Again
in Windows 10 Drivers and HardwareSpacial Sound Issue Again: Alright, so basically, I've had this problem for a while but it never really bothered me until I started playing games where knowing the direction of sounds became important. If you open sounds in control panel you have the option for spacial sound. It is currently off for me... -
I need to be able to change the Sample Rate and Bit Rate in Sound Setting
in Windows 10 Drivers and HardwareI need to be able to change the Sample Rate and Bit Rate in Sound Setting: I need to be able to change the Sample Rate and Bit Rate in Sound Setting so here is my situation as I know most people ask for it. I am on an Asus Q304UA and I am on Windows 10 Pro Version 2004 OS Version:10.0.19041 N/A Build 19041. And I need to able to change the sample... -
Spacial Sound Issue
in Windows 10 Drivers and HardwareSpacial Sound Issue: Alright, so basically, I've had this problem for a while but it never really bothered me until I started playing games where knowing the direction of sounds became important. If you open sounds in control panel you have the option for spacial sound. It is currently off for me... -
Logitech z607 no spacial sound
in Windows 10 Ask InsiderLogitech z607 no spacial sound: Hey Reddit I wanted a minimal surround sound option for my spare room "office", so purchased the z607. Using on-board Realtek jacks, outputs are all connected for 5.1, Realtek app installed, and all channels test fine via the app and Windows sound setting. The issue is that... -
Unable to set bit rate for Fast Track C400 device
in Windows 10 CustomizationUnable to set bit rate for Fast Track C400 device: I use avid (m-audio) fast track c400 with latest drivers from manufacturers web site. The problem I face is it is impossible to set the bitrate and sample rate as there is no Advanced tab in options for this device. Is there any way to switch the bitrate or sample rate via... -
Headphones and Spacial sound
in Windows 10 Drivers and HardwareHeadphones and Spacial sound: I can listen to everything through my headphones (3.5mm jack) but my computer doesn't recognize them as "headphones". They don't appear in playback devices, hardware, or anywhere else, only single option of speakers is displayed. This is stopping me from being able to use...
