Windows 10: Battery and Power Question for laptops
Discus and support Battery and Power Question for laptops in Windows 10 Ask Insider to solve the problem; If I were to set the "when I close the lid" setting to do nothing, but set the "Hibernate after this amount of time" to 10 min. Will the computer... Discussion in 'Windows 10 Ask Insider' started by /u/advancedminer13, Apr 8, 2021.
Battery and Power Question for laptops - Similar Threads - Battery Power Question
My laptop is slow on battery power
in Windows 10 GamingMy laptop is slow on battery power: For example, when I'm playing games or just watching something when it's plugged in it works fine but when it's on battery power it turns super slow. I have tried various methods such as updating my device, turning off the power saver, and various other methods but they don't... -
in Windows 10 Software and AppsMy laptop is slow on battery power: For example, when I'm playing games or just watching something when it's plugged in it works fine but when it's on battery power it turns super slow. I have tried various methods such as updating my device, turning off the power saver, and various other methods but they don't... -
battery question for Surface Laptop Studio
in Windows 10 Gamingbattery question for Surface Laptop Studio: Hello, Just purchased a Windows Surface Laptop Studio. For travel, can I use a portable 65W USB-C charger to charge it while away, or will that damage the battery? I think the standard charger that it comes with is 102W. I just want to see if I have to purchase another... -
in Windows 10 Software and Appsbattery question for Surface Laptop Studio: Hello, Just purchased a Windows Surface Laptop Studio. For travel, can I use a portable 65W USB-C charger to charge it while away, or will that damage the battery? I think the standard charger that it comes with is 102W. I just want to see if I have to purchase another... -
Laptop Battery Question
in Windows 10 Drivers and HardwareLaptop Battery Question: With the Newer Bios Update on my HP Omen 15_ce019dx, finally turned on battery care--80 percent, well in Windows shows 79 percent available? Should i re calibrate battery? or is that normal, and nothing to worry on. 183544 -
Never using battery power in a laptop
in Windows 10 SupportNever using battery power in a laptop: I have a brand new laptop and I run it on mains power all the time (constantly plugged in) does this degrade the battery in any way as I have no way of taking the battery out because it is housed inside the machine. I have Googled this and have a number of different thoughts... -
Laptop crashes on battery power
in Windows 10 BSOD Crashes and DebuggingLaptop crashes on battery power: I have Windows 10 running on my laptop. After a recent update the battery life icon vanished. I followed the instructions in the settings to switch it back on but now the laptop crashes without warning. It acts like the battery is dead but it is a months old battery and it... -
Battery question!
in Windows 10 Drivers and HardwareBattery question!: Hi, I am having to take the battery out of my laptop and re-install it to start the computer. I might add the battery is only 1 month old and is fully charged. can any one help me?... -
Battery Question
in Windows 10 Drivers and HardwareBattery Question: I recall that in the past, it was good for the battery to let it run down a certain amount, then let it charge up again. Is that still the current train of thought? My Toshiba laptop is used mostly plugged in to the mains. I note that it never charges more than 80%. My guess...
