Windows 10: Battery drained overnight. Slow and intermittent charging when plugged in with recurrent...
Discus and support Battery drained overnight. Slow and intermittent charging when plugged in with recurrent... in Windows 10 Drivers and Hardware to solve the problem; Hello community fellows, This is the third battery in my HP Pavilion Entertainment laptop. The second battery was working well during half a yer,... Discussion in 'Windows 10 Drivers and Hardware' started by Mr. Jack Hill, Aug 13, 2018.
Battery drained overnight. Slow and intermittent charging when plugged in with recurrent... - Similar Threads - Battery drained overnight
Battery draining overnight
in Windows 10 CustomizationBattery draining overnight: I installed the latest feature update for windows 10 on the 16/jan/2021 and since then i have noticed the battery on my Lenovo Legion laptop has been draining down to about 7% or less. Yesterday i uninstalled the l uninstalled that update and have not had the problem. My... -
my battery is not charging when plugged in.
in Windows 10 Performance & Maintenancemy battery is not charging when plugged in.: My battery is not charging when plugged in. I have an Dell Inspiron R17 N7010, with Windows 10. It runs OK when plugged in, but does not charge the battery.... -
battery draining overnight when my device is idle
in Windows 10 Customizationbattery draining overnight when my device is idle: I use a hp pavalion 10th gen and when it is idle in the night the battery drains from 100 to 15 or 20, i have tried everything i could do but nothing is happening pls help and tell me what to do... -
Flashing battery icon, not charging when plugged in, slow computer
in Windows 10 Drivers and HardwareFlashing battery icon, not charging when plugged in, slow computer: I have an Acer Aspire 5, and it recently began running very slowly. No internet issues, installed Windows update, cleaned up browser, cookies, start up apps, ran diagnostics, etc. I then called Acer support and they recommended doing a system reset. I did that - twice,... -
Battery will not charge when plugged in
in Windows 10 Performance & MaintenanceBattery will not charge when plugged in: My Lenovo ideapad 120S will not charge when plugged in. It is a brand new computer and I think it may be stuck in shipping mode. I have unplugged it held the power button 90 seconds and still will not work. I have also pressed the reset button and that didn't fix it. Does... -
battery charging intermittently
in Windows 10 Drivers and Hardwarebattery charging intermittently: Hello, I have a HP laptop T8S31EA#ABZ and recently my battery has started to abruptly stop charging at variable levels of charge. Keeping it connected to AC, it starts randomly to charge again but only for some minutes and then stops. I followed all the steps suggested... -
Battery draining when plugged in
in Windows 10 Performance & MaintenanceBattery draining when plugged in: I have an Alienware R4 17 Laptop. I've been trying to play games on it, but after a few hours, the laptop decides to start draining and charging the battery by small amounts. The laptop then decides to drop my game performance to unplayable levels. My understanding is that... -
Battery not charging, even when plugged in.
in Windows 10 Drivers and HardwareBattery not charging, even when plugged in.: Hi! My HP laptop for the last two years won't charge. Originally I thought it was a simply faulty power cord. But after switching it out, my computer would still be plugged in, start charging, and then stop suddenly, only to start up again at a random time. I removed my... -
Battery Icon shows drain when plugged in but battery settings shows full charge
in Windows 10 CustomizationBattery Icon shows drain when plugged in but battery settings shows full charge: This is a issue with update 1803. With this Spring Creator's Update.. my laptop battery icon in the system tray would suddenly jump from almost fully charged to "27%, plugged in, not charging" while the actual battery status when view in Windows would be between 96% and...
