Windows 10: Battery is Charging - Battery Status: 0% available plugged in, charging
Discus and support Battery is Charging - Battery Status: 0% available plugged in, charging in Windows 10 Gaming to solve the problem; Subject: Assistance Needed: Battery Stuck at 0% Despite ChargingMessage:Hello Team,I’m encountering an issue with my device battery. Although it... Discussion in 'Windows 10 Gaming' started by Rafi Rabbani, Dec 10, 2024.
  1. Battery is Charging - Battery Status: 0% available plugged in, charging
    Subject: Assistance Needed: Battery Stuck at 0% Despite ChargingMessage:Hello Team,I’m encountering an issue with my device battery. Although it indicates that it’s charging, the battery level remains stuck at 0% and does not increase. If i try to unplug the charger, the device automatically shut downs everything. Here are the details:Operating System: Windows 11 Home Single LanguageSteps I’ve Tried:Verified that the power cable and adapter are connected securely.Tried different power outlets and cables.Restarted the device while it was plugged in.Because my laptop is 2021 model, my battery s
  2. Plugged in but battery does not charge
    Step 1
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    Battery is Charging - Battery Status: 0% available plugged in, charging pbDp4sx.png
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    Step 3
    FreeBooter, Dec 10, 2024
  3. gordon99 Win User
    Battery plugged in but not charging.
    A further update on "Plugged in not charging" (PI,NC). A few days ago I deliberately discharged the laptop battery and on plugging the charger back in the battery was not charging. This time, because I had read the suggestion somewhere, I just disabled the Microsoft AC Adapter and the Microsoft ACPI-Compliant Control Method Battery in Device Manager. I then enabled them and found the battery was now charging.
    Today, as a further test, I again let the battery discharge, down to 6%. When I switch the charger back on I found the battery icon displaying the "PI,NC" message when I hovered the cursor over it. I went into Device manager and disabled both the Adapter and the ACPI. Immediately a message appeared on the screen to the effect that hardware changes had been detected and the laptop would restart, which it did. The battery icon had disappeared, as expected, but the battery charging light was on. I went into Device Manager and both Adapter and ACPI were still both showing Disabled-Code 22. The battery charging light was still on however. I enabled both Adapter and ACPI and the battery icon re-appeared, again as expected. The battery was now showing 11% charge, so I conclude, though I do not understand how, that the battery was still charging in spite of having both Adapter and ACPI disabled. As I write I have now disabled the Adapter only in Device Manager but the battery is still charging. I have now enabled the Adapter and disabled the ACPI. As the battery icon has gone off screen I will wait a few minutes before I enable it and check the degree of battery charge. The battery charging light is still on I should add.
    Having now enabled the ACPI I have found the amount of charge on the battery has increased quite a bit.
    It seems to me that, as far as my second hand Dell E5420 Latitude laptop is concerned, it is necessary to disable the Adapter and/or ACPI in Device Manager to kick the battery charging process into action. I really would like to know why this is and, more importantly, what purpose the Adapter and ACPI in Device Manager serve other than to display the battery icon and start the charging process when disabled.
    gordon99, Dec 10, 2024
  4. Battery is Charging - Battery Status: 0% available plugged in, charging
    battery charge problem - '0% available(plugged in, not charging) '
    I am getting this issue for from last week.
    Battery is not getting charged and showing as '0% available(plugged in, not charging) '.
    I had tried with driver uninstall and install. And even if removing battery and adding again.
    My laptop model is - Lenovo Flex 2.
    Please share the solution soon.
    sumanpatro, Dec 10, 2024
  1. Battery is Charging - Battery Status: 0% available plugged in, charging - Similar Threads - Battery Charging Battery
  2. Plugged in but not charge the Battery and stuck at 0%
    Plugged in but not charge the Battery and stuck at 0%: I have lenovo ideapad gaming 3 intel i5 gtx 1650 laptop and I update windows 11 24h2 update. I use daily after update and work normally but one day I open laptop and working around 2 to 3 min and suddenly switch off . I plugged the charger and on the laptop . I saw my laptop...
  3. Battery is Charging - Battery Status: 0% available plugged in, charging
    Battery is Charging - Battery Status: 0% available plugged in, charging: Subject: Assistance Needed: Battery Stuck at 0% Despite ChargingMessage:Hello Team,I’m encountering an issue with my device battery. Although it indicates that it’s charging, the battery level remains stuck at 0% and does not increase. If i try to unplug the charger, the...
  5. Battery is Charging - Battery Status: 0% available plugged in, charging
  6. Referring to: Windows 10-Battery status: 0% available, plugged in, not charging
    Referring to: Windows 10-Battery status: 0% available, plugged in, not charging: I haìve a not charging problem with my HP15 bv027, that started after the last updates unfortunately I could not say which oneTried all countermeasures found on internet, plus diagnostic of HP, without any benefit. The battery charges until the ac cable remain plugged in. If...
  7. Problem - Battery Status: 0% available (plugged in, charging)
    Problem - Battery Status: 0% available (plugged in, charging): My Toshiba Satellite L55-B5271 laptop updated to Windows 10 Version 1809 Build 17763.475 (Home, 64) a couple of weeks ago. Like every other update, I had mild annoyances occur. Like before, I fixed lost settings, file associations, and the like, while ignoring anything less...
  8. Problem - Battery Status: 0% available (plugged in, charging)
  9. Windows 10-Battery status: 0% available, plugged in, not charging
    Windows 10-Battery status: 0% available, plugged in, not charging: Hello, I have acer Aspire E15 E5 573G laptop with Win-10 Home edition. Recently I upgraded PC config to 480gb SSD (for OS only) and additional 4GB ram. After a week of usage, I stumbled upon the issue mentioned in the subject. I have tried following but in vain: Restart...
  10. Battery at 0%, plugged in not charging.
    Battery at 0%, plugged in not charging.: Hi, Recently my battery has not been charging. Initially I would notice the battery status being "plugged in not charging". Removing the power cable and reinserting it would normally solve the problem. One night I plugged my laptop in to charge (while in sleep mode) and it...
