Windows 10: Battery is not charging while connecting with adapter, it works when lid is closed
Discus and support Battery is not charging while connecting with adapter, it works when lid is closed in Windows 10 Drivers and Hardware to solve the problem; I am using HP notebook and have been facing this issue for three days. Whenever, I close the notebook lid and connect with AD adapter, battery starts... Discussion in 'Windows 10 Drivers and Hardware' started by Darshpreet Kaur, Jul 30, 2021.
Battery is not charging while connecting with adapter, it works when lid is closed - Similar Threads - Battery charging while
Laptop overheating while sleeping with lid closed, draining battery
in Windows 10 GamingLaptop overheating while sleeping with lid closed, draining battery: The computer has rebooted from a bugcheck. The bugcheck was: 0x00020001 0x0000000000000028, 0x0000000000000001, 0x0000000029b92701, 0x00000000fd200000. A dump was saved in: C:\WINDOWS\Minidump\050725-16296-01.dmp. Report Id: d9a02de4-a6cf-492e-b896-f82d75ac196b.Here is the... -
in Windows 10 Software and AppsLaptop overheating while sleeping with lid closed, draining battery: The computer has rebooted from a bugcheck. The bugcheck was: 0x00020001 0x0000000000000028, 0x0000000000000001, 0x0000000029b92701, 0x00000000fd200000. A dump was saved in: C:\WINDOWS\Minidump\050725-16296-01.dmp. Report Id: d9a02de4-a6cf-492e-b896-f82d75ac196b.Here is the... -
Battery draining while in sleep mode Lid Closed windows 11
in Windows 10 GamingBattery draining while in sleep mode Lid Closed windows 11: Technically either in sleep mode or with Lid Closed the system should be shut without any background activity but i have been facing this issue where even if i put the system to sleep mode or close the lid, the system still keeps running. the battery drains a lot and this is... -
in Windows 10 Software and AppsBattery draining while in sleep mode Lid Closed windows 11: Technically either in sleep mode or with Lid Closed the system should be shut without any background activity but i have been facing this issue where even if i put the system to sleep mode or close the lid, the system still keeps running. the battery drains a lot and this is... -
Behavior when closing lid
in Windows 10 GamingBehavior when closing lid: I have long configured my laptop to stay on when I close the lid with it plugged in and to shut down when I close the lid with the plugged pulled. I do this for several reasons but the main reason I prefer this set up is because I can close the lid of my lap top, pull the... -
in Windows 10 Software and AppsBehavior when closing lid: I have long configured my laptop to stay on when I close the lid with it plugged in and to shut down when I close the lid with the plugged pulled. I do this for several reasons but the main reason I prefer this set up is because I can close the lid of my lap top, pull the... -
When lid closed
in Windows 10 CustomizationWhen lid closed: Hey Microsoft Community! I want to "Do nothing" when my laptop lid is closed. I was able to set this in Control Panel. I don't want to drain my battery, though, so I want it to hibernate about 5 minutes after there is not activity. Thank you!... -
adapter not charging the battery
in Windows 10 BSOD Crashes and Debuggingadapter not charging the battery: Hello, I have Lenovo Y520 laptop. somehow i let the battery completely drain and the laptop got shut down. Since then my battery does not charge. even when i left the adapter plugged in for quite a while the status still shows "0% available, plugged in charging". I... -
Plugging in power adapter while battery is connected.
in Windows 10 Performance & MaintenancePlugging in power adapter while battery is connected.: I have my battery in my laptop and I also have the power adapter plugged in at the same time. There are mixed opinions on the subject whether it kills the battery or not . Some say once the battery reaches 100% the charging process shuts down. Battery doesn't kick in until...
