Windows 10: Battery percentage had disappeared on power mode slider menu.
Discus and support Battery percentage had disappeared on power mode slider menu. in Windows 10 Ask Insider to solve the problem; [ATTACH] submitted by /u/ekinyuksel12 [link] [comments]... Discussion in 'Windows 10 Ask Insider' started by /u/ekinyuksel12, Nov 26, 2020.
  1. Battery percentage had disappeared on power mode slider menu.
  2. Helmut Win User
    Battery Slider vs Power Options
    The Battery slider power control is not completely independent, obviously some settings would be common.
    Early versions of Windows 10 had more than one Power Plan, but they changed it into the one plan, Balanced (recommended) and then added a Power Mode slider control to the Battery icon.
    Which makes it a lot easier than going to Power Plans.
    i.e. The Power Mode slider control is the equivalent of a different Power Plan.
    All part of a general shift from the old Control Panel to the Settings App.
    Helmut, Nov 26, 2020
  3. Fall Creators Update: Missing power mode slider in the taskbar
    This is a bug, as explained in this article.
    "if you switch to the balanced power mode from the Control Panel, the slider will disappear again and that’s the bug." So basically after switching power modes via control panel, the power mode slider goes away and
    seemingly cannot be fixed (even after returning to to balanced power mode).
    Another article
    "However, once you open the Control Panel and switch to the balanced power mode, the battery slider will disappear again. There is a big bug. It may be casued by the result of settings migrating from
    the Control Panel to the Settings app."
    Jeffrey McClain, Nov 26, 2020
  4. suryapolu Win User
    Battery Power slider missing.
    thanks for replying back par_0511.
    I tried all the methods that u suggested, but the battery slider is still missing.
    suryapolu, Nov 26, 2020
  1. Battery percentage had disappeared on power mode slider menu. - Similar Threads - Battery percentage disappeared
  2. Battery Power slider missing.
    Battery Power slider missing.: As the title says, the battery slider in Windows 10 is missing. It was there a few days ago but today when I checked it, it wasn't. I haven't changed anything recently in the power options. I checked the internet for a fix, but all of them are nothing but "keep the power...
  3. battery percentage at 255%
    battery percentage at 255%: Recently I uninstalled and then reinstalled the battery in my computer. I did this because the percentage charge was showing at 255%. Upon reinstallation the number has remained the same at 255% ever since. Is there a way of resetting the battery to set the maximum limit at...
  4. Battery Percentage not showing
    Battery Percentage not showing: I have Windows 10 Home edition. It do not show the battery percentage. I enabled it using Device Manager. But when i shut down and turn on the laptop I need to enable it again. In Taskbar Settings Power icon is enabled. What can I do about this?...
  5. Battery Slider vs Power Options
    Battery Slider vs Power Options: What bearing if any does the slider have on the power options (from control panel) I slid it to better battery but the power plan was still set to balanced? Are they completely independent? I needed to leave my laptop on over night and the fan kept starting up (not sure...
  6. How to disable Power Slider in Battery on Taskbar
    How to disable Power Slider in Battery on Taskbar: So Basically I want to know how to disable the Power Slider( As shown in the yellow circle below) and I know you can do it because I used to have it but I messed around with the power settings and managed to make this pop up again. So please somebody tell me how to disable it...
  7. battery percentage
    battery percentage: after updating to 1809 my battery percentage does not not change from 100% nor doed percentage show in taskbar icon https://answers.microsoft.com/en-us/windows/forum/all/battery-percentage/c870e216-a100-4c31-ac0b-665f3b954b17
  8. Battery mode slider missing !!!
    Battery mode slider missing !!!: Another unknown problem ... [ATTACH] https://answers.microsoft.com/en-us/windows/forum/windows_10-other_settings/battery-mode-slider-missing/b50a43cc-5e1c-4a22-ba7d-4c4f4af689f9
  9. Battery Percentage Difference
    Battery Percentage Difference: My Laptop's facing a Battery Percentage Difference Issue Asus FX553VE - Windows 10 Home Single Language v1803 Build 17134.167 When I hover my mouse over the battery icon on the Desktop it shows for example given below 82%, but on clicking the icon it says 81%. So there's...
  10. Power Mode Slider
    Power Mode Slider: Since the Power Mode Slider can be set differently for Plugged In, and not Plugged In, why would I ever want it set to anything other than Best Performance when Plugged In? 100232
