Windows 10: Battery Power Icon missing from taskbar
Discus and support Battery Power Icon missing from taskbar in Windows 10 Gaming to solve the problem; The battery icon has disappeared from my Surface 7 Pro taskbar. Running Windows 10 v. 22H2. None of the documentation found online contained a... Discussion in 'Windows 10 Gaming' started by Donald Eager, Mar 2, 2023.
  1. Battery Power Icon missing from taskbar
    The battery icon has disappeared from my Surface 7 Pro taskbar. Running Windows 10 v. 22H2. None of the documentation found online contained a solution. Either the suggestions did not work or else the instructions did not match what I saw on my PC.
  2. dekayd Win User
    Cannot find power icon in taskbar
    Have you tried the suggestions listed on the right side of the screen, Showing the battery icon on the taskbar, yet?
    dekayd, Mar 2, 2023
  3. Battery icon is missing from taskbar
    This is Sudha Independent Advisor and user like you. Please follow below steps to solve your issue
    o check the status of your battery, select the battery icon in the taskbar. To add the battery icon to the taskbar:
    Select Start > Settings > Personalization > Taskbar, and then scroll down to the notification area. Choose Select which icons appear on the taskbar, and then turn on the Power toggle. (Note: The Power toggle is not visible on a system such as a desktop PC that
    doesn't use battery power.) If you still don't see the battery icon, select Show hidden icons on the taskbar, and then select the battery icon.
    On a device that uses battery power, if you select Start > Settings > Personalization > Taskbar and the Power toggle is greyed out or not visible, in the search box on the taskbar, type device manager, and then select Device Manager in the list of results.
    Under Batteries, right-click the battery for your device, select Disable, and select Yes. Wait a few seconds, and then right-click the battery and select Enable. Then restart your device.
    If you select Start > Settings > Personalization > Taskbar and turn on the Power toggle, but the battery icon does not appear on the taskbar, in the search box on the taskbar, type task manager, and then select Task Manager in the list of results. On the Processes
    tab under Name, right-click Explorer, and then select Restart.
    reference link :
    https://support.microsoft.com/en-in/help/402734...
    Sudha Goswami, Mar 2, 2023
  4. Battery Power Icon missing from taskbar
    To check the status of your battery, select the battery icon in the taskbar. To add the battery icon to the taskbar:
    * Select Start > Settings > Personalization > Taskbar, and then scroll down to the notification area. Choose Select which icons appear on the taskbar, and then turn on the Power toggle. (Note: The Power toggle is not visible on a system such as a desktop PC
    that doesn't use battery power.) If you still don't see the battery icon, select Show hidden icons on the taskbar, and then select the battery icon.
    * On a device that uses battery power, if you select Start > Settings > Personalization > Taskbar and the Power toggle is greyed out or not visible, in the search box on the taskbar, type device manager, and then select Device Manager in the list of results.
    * If you select Start > Settings > Personalization > Taskbar and turn on the Power toggle, but the battery icon does not appear on the taskbar, in the search box on the taskbar, type task manager, and then select Task Manager in the list of results. On the
    Processes tab under Name, right-click Explorer, and then select Restart.
    sunil parmar, Mar 2, 2023
  1. Battery Power Icon missing from taskbar - Similar Threads - Battery Power Icon
  2. Battery Power Icon missing from taskbar
    Battery Power Icon missing from taskbar: The battery icon has disappeared from my Surface 7 Pro taskbar. Running Windows 10 v. 22H2. None of the documentation found online contained a solution. Either the suggestions did not work or else the instructions did not match what I saw on my PC....
  3. Battery Power Icon missing from taskbar
  4. battery icon missing from taskbar
    battery icon missing from taskbar: today my battery icon disappeared from the taskbar and i have tried the methods online to restore it but impossible. When i go to taskbar, personilsation etc i eventually get to the page where they show whether the icons are off or on. The battery icon is shown as being ON...
  5. Battery Power Icon in Taskbar
    Battery Power Icon in Taskbar: I usually keep the Battery charge condition displayed Icon displayed in the Taskbar. Today, I noticed the Battery Icon had disappeared. I went to settings and found the Battery Icon "On/Off was greyed out so I could not turn it on or off. All the other icon controls were...
  6. Battery icon is missing from taskbar
    Battery icon is missing from taskbar: Don't know but after updating windows 10 2004 my battery icon is missing from taskbar please help me to restore back https://answers.microsoft.com/en-us/windows/forum/all/battery-icon-is-missing-from-taskbar/2ab327a6-7064-409f-bbb0-02facb2a137b
  7. Battery icon is missing from taskbar
    Battery icon is missing from taskbar: Don't know but i think after 2004 update my laptop battery icon is missing from taskbar in windows 10 https://answers.microsoft.com/en-us/windows/forum/all/battery-icon-is-missing-from-taskbar/4a3cb3fd-53cc-48e0-bed5-8c0da1f227e6
  8. Battery icon is missing from taskbar
    Battery icon is missing from taskbar: After 2004 update of windows 10 my battery icon is missing from taskbar help me to place it back on taskbar https://answers.microsoft.com/en-us/windows/forum/all/battery-icon-is-missing-from-taskbar/583524ed-7202-4a41-898f-ca3a3aae14fb
  9. Power icon missing from taskbar
    Power icon missing from taskbar: After the recent windows update. Power icon went missing from the taskbar. Settings are turned on for icons to display. There's also a lag in opening new application after the update. Performance went too slow after the update. I really wanted to uninstall the new update....
  10. Battery/power icon on taskbar
    Battery/power icon on taskbar: help please. The battery icon in Turn system icons on or off is on, but it is gray, not blue. I don't have it on my taskbar. I followed every idea available, but have failed to get on my task bar. I had it earlier, but when I restarted for an update, it disappeared and I...
