Windows 10: Battery saving mode sets screen backlight to zero percent and disables USB ports while...
Discus and support Battery saving mode sets screen backlight to zero percent and disables USB ports while... in Windows 10 Customization to solve the problem; ever since i bought my laptop with windows 10 few years ago, i am having this one problem to which, unfortunately, i could not find any solution to... Discussion in 'Windows 10 Customization' started by ViridWhisper984, Apr 29, 2019.
Battery saving mode sets screen backlight to zero percent and disables USB ports while... - Similar Threads - Battery saving mode
Both batteries are at zero percent and not charging, what do I do?
in Windows 10 GamingBoth batteries are at zero percent and not charging, what do I do?: The only way to use the laptop is by being connected directly to the charger. Any help with this? https://answers.microsoft.com/en-us/windows/forum/all/both-batteries-are-at-zero-percent-and-not/c5de5adb-1da7-43df-9107-f2d6430c51c7 -
in Windows 10 Software and AppsBoth batteries are at zero percent and not charging, what do I do?: The only way to use the laptop is by being connected directly to the charger. Any help with this? https://answers.microsoft.com/en-us/windows/forum/all/both-batteries-are-at-zero-percent-and-not/c5de5adb-1da7-43df-9107-f2d6430c51c7 -
Will usb power stop after setting USBTOR to disable USB port?
in Windows 10 GamingWill usb power stop after setting USBTOR to disable USB port?: I am using USBTOR settings in Registry Editor to control the USB port.However I will need those USB ports to provide powers to another device. May I know does that affect the stability or even cannot provide power of those USB ports?... -
in Windows 10 Software and AppsWill usb power stop after setting USBTOR to disable USB port?: I am using USBTOR settings in Registry Editor to control the USB port.However I will need those USB ports to provide powers to another device. May I know does that affect the stability or even cannot provide power of those USB ports?... -
Battery drains to zero in sleep mode - Windows 11
in Windows 10 Software and AppsBattery drains to zero in sleep mode - Windows 11: I have Mi Notebook Horizon Ultra Edition 14 i7 and having strange problem of battery draining in sleep mode, since updated to Windows 11.What happens is ... If I close lid with charger plugged-in and put it to sleep and then remove charger when done do not open lid. By next... -
DISABLE USB PORT
in Windows 10 Network and SharingDISABLE USB PORT: HI, I FOOLISHLY DISABLED USB PORT OPTION FROM BIOS NOW NEITHER KEYBOARD NOR MOUSE IS WORKING PLEASE HELP ME https://answers.microsoft.com/en-us/windows/forum/all/disable-usb-port/0ed72132-5610-414c-b7cf-ed6add623b1c -
Disable a USB Port
in Windows 10 Drivers and HardwareDisable a USB Port: Im having a hughe problem with a USB Port on my laptop I accidently rmoved a small blsck piece from the USB Port and now windows its showing an annoying icon and playing a sound that notification is making my computer stop working specially youtube, it pauses the video how... -
forced battery saving mode while in game
in Windows 10 Customizationforced battery saving mode while in game: ever since i bought my laptop with windows 10 few years ago, i am having this one problem to which, unfortunately, i could not find any solution to this day. i am traveling a lot and i need to use inverters for charging my laptop and while i am charging - all is fine, but... -
Saving the power to USB ports
in Windows 10 Drivers and HardwareSaving the power to USB ports: The drives connected to my PC through the USB ports seem to save power. I have two drives and they are self powered, they use AC power. I found out that the fan of the drive is not spinning - that means it doesn’t get power from the USB port. I tried to disable the power...
