Windows 10: Battery still not detected after following DaveM121's advice exactly.
Discus and support Battery still not detected after following DaveM121's advice exactly. in Windows 10 Drivers and Hardware to solve the problem; Have Dell Latititude E7240 12.5" laptop, 128Gb SSD, 8Gb RAM, Win 10 H 64bit with battery problems. The battery is not charging, the chargers 2 both... Discussion in 'Windows 10 Drivers and Hardware' started by HelpTheAggrieved, Sep 21, 2020.
Battery still not detected after following DaveM121's advice exactly. - Similar Threads - Battery still detected
DaveM121
in Windows 10 GamingDaveM121: I Dave, I am having this same issue and durgarao39 had back in Sept. I followed your answer to this issue that you suggested and below is what my results were can you help me to correct this window issue?Issue: Failed to connect to an IPC Port: The system cannot find the file... -
DaveM121
in Windows 10 BSOD Crashes and DebuggingDaveM121: I Dave, I am having this same issue and durgarao39 had back in Sept. I followed your answer to this issue that you suggested and below is what my results were can you help me to correct this window issue?Issue: Failed to connect to an IPC Port: The system cannot find the file... -
Battery not Detected but still working
in Windows 10 Drivers and HardwareBattery not Detected but still working: I got the issue this morning, but if I unplug the laptop, it still works. I don't know much about removing the battery, but I know that this one is not removable.... -
DaveM121
in Windows 10 BSOD Crashes and DebuggingDaveM121: Thank you, for some reason its not letting me reply to that post. I uninstalled it but backed it up in a zip just in case. Thank you for you time https://answers.microsoft.com/en-us/windows/forum/all/davem121/27b50b55-7f30-4a77-8d39-e74bf3a54846 -
Laptop Battery Buying Advice
in Windows 10 Drivers and HardwareLaptop Battery Buying Advice: May have to replace my battery. Seen them on Ebay and Amazon but was wondering how to gauge what's a smart/safe buy beyond the ratings and warranty as many seem similar in that regard. Thanks 152371 -
in Windows 10 SupportLaptop Battery Buying Advice: May have to replace my battery. Seen them on Ebay and Amazon but was wondering how to gauge what's a smart/safe buy beyond the ratings and warranty as many seem similar in that regard. Thanks 152371 -
Advice following SSD upgrade
in Windows 10 Drivers and HardwareAdvice following SSD upgrade: I have a rather basic question and would be very grateful for any advice. I've recently installed an SSD to replacing my hard drive on a machine that I put together myself a few years ago and then completed a fresh install of Windows 10. Do I need to re-install the the... -
Battery charging advice
in Windows 10 SupportBattery charging advice: When the battery is fully charged is it necessary to switch the AC charge off? I have had contradictory advice on this, and now due to a charging / battery issue with my 2-in-1 Tablet PC I need to know. If I do turn AC off I usually (not always) find I cannot switch charging... -
Few probelms after following bad advice
in Windows 10 SupportFew probelms after following bad advice: I needed more space in C: and found about 50GB in C:\windows\Users'Win7. My system was upgraded from Win 7 and I wondered if this folder was something ex-Win7 I didn't need anymore. I went onto MS Support chat and they said Yes. But it removed most of the files on my Desktop....
