Windows 10: Battery will still goes "plugged in, charging" after I removed the power cord
Discus and support Battery will still goes "plugged in, charging" after I removed the power cord in Windows 10 Performance & Maintenance to solve the problem; Hello,I have a lenovo thinkbook and is currently running windows 10. Every now and then, if I finished charging my laptop and unplug the cord doesnt... Discussion in 'Windows 10 Performance & Maintenance' started by DimasEB, Jun 20, 2021.
Battery will still goes "plugged in, charging" after I removed the power cord - Similar Threads - Battery still goes
Windows 10 screen power cord goes black for ~1s when um/plugging power cord
in Windows 10 Performance & MaintenanceWindows 10 screen power cord goes black for ~1s when um/plugging power cord: Hello folks, I had this issue and the locked answer was related to turning off virus protection not helpful The solution for me was to: 1. EDIT THE BIOS and DISABLE "boot when power is applied"I have a lenovo x230 laptop running Win10. This problem plagued me for over a week,... -
Battery not charging. Plugged in, not charging
in Windows 10 Drivers and HardwareBattery not charging. Plugged in, not charging: Hello, I am using HP pavilion 360 , it has been months since the message is reading "plugged in, not charging" and now the percentage has decreased to 75%. I have tried to reinstall Microsoft ACPI- Complaint Control Method Battery but it didn't work. Now what should I do?... -
Battery stops charging after plugging in
in Windows 10 Drivers and HardwareBattery stops charging after plugging in: [IMG]BWhem I charge my computer, it stops after 5 seconds or so. Please notice on the battery report how this reflects. I have already tried every solution that there is. Can somebody interpretate my battery report and tell me what’s going on?... -
Battery plugged in, not charging
in Windows 10 Drivers and HardwareBattery plugged in, not charging: I have my USB-C charging cable plugged into the charging port of my laptop. However, the batter icon on my bottom right says (when I moused over it) "5% available (plugged in, not charging). Can't solve this issue. Anyone with solution ? I am on Window 10 Pro, ThinkPad X1... -
Battery plugged in but not charging.
in Windows 10 Drivers and HardwareBattery plugged in but not charging.: I have recently noticed that the battery on my Dell Laptop, which runs on Windows 10. (64 bit) is not charging and displays the note "plugged in but not charging. I have read a number of possible easy solutions, none of which seem to work. The adapter and leads etc seem to be... -
Power cord not running laptop but is charging battery.
in Windows 10 CustomizationPower cord not running laptop but is charging battery.: My laptop is currently charging with the power cord but does not seem to be running it at all. The battery is depleting while I am using the laptop to the point that it will shutdown because of low battery even though it is plugged in. Battery will then charge. Icon bar at... -
Power mode plugged in but battery is not charging
in Windows 10 BSOD Crashes and DebuggingPower mode plugged in but battery is not charging: I am using HP Pavillion Notebook with windows 10 home basic OS installed on it. It is now showing that power mode is plugged in but battery is still not charging. It is also not starting without any power source plugged in.... -
battery plugged in not charging
in Windows 10 Drivers and Hardwarebattery plugged in not charging: My battery won't charge. Says plugged in not charging https://answers.microsoft.com/en-us/windows/forum/windows_10-hardware/battery-plugged-in-not-charging/88e70d57-e863-4a95-8925-9bf98ee0aa69 -
battery plugged in but not charging
in Windows 10 Customizationbattery plugged in but not charging: Status on laptop shows battery plugged in but not charging (battery is at 80%). When I disconnect the mains, the laptop shuts down....
