Windows 10: Bluetooth Battery Level via Battery System Icon
Discus and support Bluetooth Battery Level via Battery System Icon in Windows 10 Drivers and Hardware to solve the problem; We have all been there when our wireless devices (mouse/keyboard) stop responding. Or in my instance, using the Surface Pen buttons and suddenly they... Discussion in 'Windows 10 Drivers and Hardware' started by ChrisMandragon, Feb 23, 2019.
Bluetooth Battery Level via Battery System Icon - Similar Threads - Bluetooth Battery Level
Game Bar and Bluetooth Battery Level Mismatch
in Windows 10 Software and AppsGame Bar and Bluetooth Battery Level Mismatch: I bought an Xbox controller specifically for PC gaming a year or two ago, and I've recently noticed an issue with using the Game Bar. While it is nice to have the battery level there, it seems to be inaccurate. I had my controller plugged in to charge for a few hours, and on... -
Battery icon not showing correct level
in Windows 10 GamingBattery icon not showing correct level: Hello.The battery icon is designed in a way so it is showing much lower level than the procentage it shows when you mark the icon.example: the battery is at 48% and if you look at the icon only you would think that the level is 15-20%, with level at 20-25% it looks like the... -
in Windows 10 Software and AppsBattery icon not showing correct level: Hello.The battery icon is designed in a way so it is showing much lower level than the procentage it shows when you mark the icon.example: the battery is at 48% and if you look at the icon only you would think that the level is 15-20%, with level at 20-25% it looks like the... -
225% battery level but don't show the juice in the battery icon
in Windows 10 Drivers and Hardware225% battery level but don't show the juice in the battery icon: I just recently got my laptop fixed & got the new Windows 10 software installed. When I went to go use it everytime the battery is full charge, I unplug the charger, the computer always shuts off. Also when I booted it back up, it said my battery level is at 225%, plus... -
battery level
in Windows 10 Customizationbattery level: At one point windows ask if I wanted the battery level to be less when plugged in. Unfortunately, I updated. Now a want a full charge on the battery so computer can be used while traveling. I can't find the place to change it back to full power charge. Can anyone help???... -
Polling Bluetooth Battery level with Powershell
in Windows 10 Drivers and HardwarePolling Bluetooth Battery level with Powershell: I know with Windows 10 1803 we are able to see the battery level of connect wireless Bluetooth devices that support it (Such as the Surface Mouse) Is there a PowerShell command that can be run to display the battery level for these devices as well? One exists for the... -
Viewing battery level for Bluetooth Headphones
in Windows 10 Drivers and HardwareViewing battery level for Bluetooth Headphones: Hi, does anyone know how I can find the battery percentage for Bluetooth headphones? I googled it and it only had stuff for mouse, keyboard, pen, etc BUT NONE FOR HEADPHONES!!! I need my headphones to work and it is important for me to know when I need to charge it so it... -
Battery level of external Bluetooth devices
in Windows 10 CustomizationBattery level of external Bluetooth devices: I use updated Surface Pro 4 laptop. It works without any problems but I want to find out how I can check the battery level of the connected external Bluetooth devices, for instance the mouse. I cannot find the setting anywhere... -
battery level icon on taskbar
in Windows 10 Customizationbattery level icon on taskbar: On my other computer running Windows 10, I have a battery icon showing in my system tray that shows how much charge is left in the battery. On my current computer, this is not there and I cannot find how to add it. Any suggestions?...
bluetooth system tray icon battery program
