Windows 10: Bluetooth Headphone does not connect for Audio.
Discus and support Bluetooth Headphone does not connect for Audio. in Windows 10 Drivers and Hardware to solve the problem; I have a WI-C100 Wireless In-ear Headphone, which worked fine for several months. Now, it connects with the PC, but not for audio and calls. It just... Discussion in 'Windows 10 Drivers and Hardware' started by Thevindu, Nov 14, 2023.
  1. Thevindu Win User
    I have a WI-C100 Wireless In-ear Headphone, which worked fine for several months. Now, it connects with the PC, but not for audio and calls. It just says 'connected'. After that, I can't even turn off my headphones for a few minutes. It works with other devices without an issue.I have a Windows 10 PC. ASUS Zenbook Flip 13 UX363EIMG: https://filestore.community.support.microsoft.com/api/images/f57442e4-1983-415f-96bf-670edd59b6a3?upload=true&fud_access=wJJIheezUklbAN2ppeDns8cDNpYs3nCYjgitr%2bfFBh2dqlqMuW7np3F6Utp%2fKMltnRRYFtVjOMO5tpbpW9UyRAwvLeec5emAPixgq9ta07Dgnp2aq5eJbnfd%2fU3qhn5498Q
  2. caperjack Win User
    bluetooth headphones
    setting up win10 Bluetooth and my Bluetooth headphones work fine ,but every time I reconnect the headphones I have to delete them from Bluetooth settings and let win10 pickup the headphones again ,before they will pair ,then win10 want to reboot to add the headphones ,I reboot and they work fine ,but next time I plug the headphone in again they will not pair ,don't even get an option to pair till I delete the head phones from the list ,, any suggestions ,, thank
    caperjack, Nov 14, 2023
  3. Naveen_M Win User
    Bluetooth headphones 'connected', Audio, Voice not connected
    I understand how difficult it is, when the device doesn't work in the way it should. For us to isolate the issue and to assist you better, we'd like to ask you a few questions.
    1. What is the make and the model number of the computer?
    2. What is the make and the model number of the headphone?
    3. Are the speakers muted when the headphone is plugged in?
    4. Are you aware of any changes made on the computer prior to this issue?
    We can try a few steps and check if we can fix this.
    Method 1: Remove and connect the Bluetooth headphone and check.
    1. Press Windows key + I together to open Settings.
    2. Click on Devices > Bluetooth & other devices.
    3. Now click on the Bluetooth headphone and click on Remove device.
    4. Turn off Bluetooth and the headphone and turn them back on, and Connect.
    If the issue persists, try method 2.
    Method 2: Enable the Bluetooth headphone.
    1. Right click on the Volume icon on the taskbar.
    2. Click on Sounds.
    3. Navigate to Playback tab.
    4. Right click on an empty space and select Show Disabled Devices.
    5. Check if the Bluetooth headset is showing in the list.
    6. Right click on the Bluetooth headphone and click Enable and check.
    If the issue persists, I'd suggest you to refer this article on
    Fix sound problems in Windows 10
    and try the suggestions showing under the
    Run the audio troubleshooter
    , Fix your audio driver,
    Set default device
    , and Turn off Audio Enhancements section and update us on the result.
    We'll be waiting for your response.
    Naveen M
    Naveen_M, Nov 14, 2023
  4. Bluetooth Headphone does not connect for Audio.
    No audio through connected Bluetooth device
    I am having problems playing audio from my Windows PC through my Bose Bose AE2 Bluetooth headphones.
    1) I have previously connected to these headphones without any issues. The audio was fine
    2) at some point, the audio started experiencing distortions and disconnects
    3) I can now no longer play any audio through the headphones from the PC
    In the Bluetooth and other device settings menu, my headphones are connected. I have also tried un-pairing and re-pairing the device several times. The device manager recognizes the headphones in the bluetooth dropdown menut. In the Sound settings on Windows, my headphones are listed as a playback device, but are listed as disconnected and cannot be connected from that menu. Note: this is different from the bluetooth and other devices menu, which says that I AM connected.
    My windows drivers are up to date, I have updated my headphones to the latest drivers as well. My headphones connect without issue to other devices (laptop and cell phone both). I feel as though I have taken all the basic troubleshooting steps and am not getting anywhere.
    Bluetooth Bother, Nov 14, 2023
  1. Bluetooth Headphone does not connect for Audio. - Similar Threads - Bluetooth Headphone does
  2. bluetooth headphones connecting but not allowing audio?
    bluetooth headphones connecting but not allowing audio?: hi,i've seen another question similar to mine but nothing i've tried works! i have jbl wave100tws headphones and they have connected and played audio just fine up until the last couple of days. they connect perfectly fine to other devices, just this laptop :my headphones do...
  3. Bluetooth Headphone does not connect for Audio.
    Bluetooth Headphone does not connect for Audio.: I have a WI-C100 Wireless In-ear Headphone, which worked fine for several months. Now, it connects with the PC, but not for audio and calls. It just says 'connected'. After that, I can't even turn off my headphones for a few minutes. It works with other devices without an...
  5. bluetooth headphones connecting as microphone but not audio
    bluetooth headphones connecting as microphone but not audio: After a driver updated my bluetooth devices connect as voice but not as audio I have tried to:Connect it manually in the sound managment nothing happen, it doesn´t connectUninstall and install drivers nothing happenReturn to the previous version nothing happenTrobleshooting...
  6. bluetooth headphones connected but not playing audio
    bluetooth headphones connected but not playing audio: i connected my bluetooth headphones to my laptop but they arent connected to audio or playing sound. i tried connecting them to my phone and it worked. are my headphones broken or is it my computer.im using a mpow 059 for headphones and a HP Laptop 17-by2xxx notebook pc...
  7. Bluetooth Headphones Connected but no audio plays.
    Bluetooth Headphones Connected but no audio plays.: I have a pair of Mee BTX2 bluetooth earphones that work normally on my phone but not on my laptop Asus Zephyrus GA502DU. I can pair and connect to the earphones and they play audio only when the hands-free device is selected as the playback device, not the stereo mode which...
  8. Bluetooth Headphones Connect - But do not connect audio.
    Bluetooth Headphones Connect - But do not connect audio.: I have been trying to connect my new bluetooth headphones to my desktop computer. They are able to connect - but I am unable to select them as an audio output device. I have tried setting bluetooth services to automatic, as well as turning bluetooth on and off / removing and...
  9. Bluetooth headphones won't connect audio
    Bluetooth headphones won't connect audio: I bought a new pair of Sony WF-1000XM3 headphones and have been trying to connect them to my computer but the audio wont connect. I already scoured the internet for a solution and tried every solution listed in this thread...
  10. Bluetooth headphones 'connected', Audio, Voice not connected
    Bluetooth headphones 'connected', Audio, Voice not connected: When I usually connect my headphones to my computer, after connected, the words "Audio, Voice" show up next to it. Today it stopped doing that and I'm getting nothing in the way of sound. it says 'connected' but not 'audio, voice' and of course, I'm getting no sound. The...
