Windows 10: Bluetooth headphones remain in connection mode with blinking blue light while audio is...
Discus and support Bluetooth headphones remain in connection mode with blinking blue light while audio is... in Windows 10 Drivers and Hardware to solve the problem; I am having problems with the bluetooth functionality on my desktop computer.I have done a lot of debugging. I will try and describe the problem that... Discussion in 'Windows 10 Drivers and Hardware' started by EricHenry2, May 15, 2021.
Bluetooth headphones remain in connection mode with blinking blue light while audio is... - Similar Threads - Bluetooth headphones remain
bluetooth headphones connecting but not allowing audio?
in Windows 10 Gamingbluetooth headphones connecting but not allowing audio?: hi,i've seen another question similar to mine but nothing i've tried works! i have jbl wave100tws headphones and they have connected and played audio just fine up until the last couple of days. they connect perfectly fine to other devices, just this laptop :my headphones do... -
Bluetooth Headphone does not connect for Audio.
in Windows 10 Software and AppsBluetooth Headphone does not connect for Audio.: I have a WI-C100 Wireless In-ear Headphone, which worked fine for several months. Now, it connects with the PC, but not for audio and calls. It just says 'connected'. After that, I can't even turn off my headphones for a few minutes. It works with other devices without an... -
Why is my disk active light blinking while in sleep mode?
in Windows 10 GamingWhy is my disk active light blinking while in sleep mode?: My PC normally uses ~70 watts at idle. When I place it into sleep mode, it normally goes down to 0 watts. But sometimes, I come back to find that it is back to 125 watts by itself and the hard drive light is blinking. I turn on the monitor and there is no signal, so the OS is... -
in Windows 10 Software and AppsWhy is my disk active light blinking while in sleep mode?: My PC normally uses ~70 watts at idle. When I place it into sleep mode, it normally goes down to 0 watts. But sometimes, I come back to find that it is back to 125 watts by itself and the hard drive light is blinking. I turn on the monitor and there is no signal, so the OS is... -
in Windows 10 BSOD Crashes and DebuggingWhy is my disk active light blinking while in sleep mode?: My PC normally uses ~70 watts at idle. When I place it into sleep mode, it normally goes down to 0 watts. But sometimes, I come back to find that it is back to 125 watts by itself and the hard drive light is blinking. I turn on the monitor and there is no signal, so the OS is... -
bluetooth headphones connecting as microphone but not audio
in Windows 10 Gamingbluetooth headphones connecting as microphone but not audio: After a driver updated my bluetooth devices connect as voice but not as audio I have tried to:Connect it manually in the sound managment nothing happen, it doesn´t connectUninstall and install drivers nothing happenReturn to the previous version nothing happenTrobleshooting... -
Bluetooth Headphones Connect - But do not connect audio.
in Windows 10 Drivers and HardwareBluetooth Headphones Connect - But do not connect audio.: I have been trying to connect my new bluetooth headphones to my desktop computer. They are able to connect - but I am unable to select them as an audio output device. I have tried setting bluetooth services to automatic, as well as turning bluetooth on and off / removing and... -
Bluetooth headphones won't connect audio
in Windows 10 BSOD Crashes and DebuggingBluetooth headphones won't connect audio: I bought a new pair of Sony WF-1000XM3 headphones and have been trying to connect them to my computer but the audio wont connect. I already scoured the internet for a solution and tried every solution listed in this thread... -
Bluetooth headphones 'connected', Audio, Voice not connected
in Windows 10 Drivers and HardwareBluetooth headphones 'connected', Audio, Voice not connected: When I usually connect my headphones to my computer, after connected, the words "Audio, Voice" show up next to it. Today it stopped doing that and I'm getting nothing in the way of sound. it says 'connected' but not 'audio, voice' and of course, I'm getting no sound. The...
