Windows 10: Bootcamp Slow Wifi Problem Changing Network Adapter Driver Wont Fix Either
Discus and support Bootcamp Slow Wifi Problem Changing Network Adapter Driver Wont Fix Either in Windows 10 Customization to solve the problem; Hi,Ive been trying to fix this problem with Bootcamp, I dont know why this is happening but when I do a speed test on my phone it gets the wifi speed... Discussion in 'Windows 10 Customization' started by IxBinky, May 6, 2021.
  1. IxBinky Win User
    Hi,Ive been trying to fix this problem with Bootcamp, I dont know why this is happening but when I do a speed test on my phone it gets the wifi speed that I am supposed to be getting but when I run a speed test on bootcamp its getting 1-10 mbps. I have tried searching up a solution many times like running the apple software update and have also tried changing the Network Adapter Driver that my mac uses but its still the same. Please Help Me Fix This Problem.
  2. Remon Ont Win User
    Slow internet connection from Wifi - Network adaptor
    Hi Maegen,
    Slow internet connection could be due to outdated network adapter driver or Wi-Fi signal interruptions.
    We would like to know some additional information to better isolate the issue:
    • Have you tried updating your network adapter driver?
    • Do you have any anti-virus or 3rd party security app running?
    • Is your computer updating Windows or other programs?
    • Have you done any changes on your computer prior to the issue?
    In the meantime, we suggest that you try to run Network Adapter troubleshooter and
    Internet Connection troubleshooter. It will find and fix problems with wireless network adapters and Internet connections. Follow the steps provided below:
    • Press Windows key + X and select Settings.
    • Click Update & Security, then choose Troubleshoot.
    • Click Internet Connections and Network Adapter.
    • Click Run the troubleshooter.
    We will wait for your response.
    Remon Ont, May 6, 2021
  3. Gino Des Win User
    Issues with network adapters
    Hi Alfonso,
    To resolve this issue, we suggest that you run the Network troubleshooter when you switch from WiFi to Ethernet connection. The Network troubleshooter can help diagnose and fix common connection problems including clearing the network cache to obtain a new
    IP from the new network. Kindly follow the steps below:
    • In the search box on the taskbar, type Identify and repair network problems, and then select
      Identify and repair network problems from the list of results.
    • Follow the steps in the troubleshooter and see if that fixes the problem.
    If the issue persists, kindly try the troubleshooting steps on the following link:
    Fix network connection issues in Windows 10
    We recommend that you try the steps on the Update the network adapter driver,
    Run the Network troubleshooter followed by networking commands, and Use network reset to reinstall network devices sections.
    Let us know how it goes for us to assist you further.
    Gino Des, May 6, 2021
  4. Arun B J Win User
    Windows 10 - Cannot connect to WiFi. How to uninstall network adapter driver?
    Thank you for your reply.
    • Right click on Windows icon on the taskbar.
    • Select Control panel.
    • Click on network and sharing center.
    • At the left top corner click on Change adapter settings.
    • There you will be able to see the Driver name of the network Adapter next to the Icon.
    • Then you can go to device manager and check for that network adapter and you can uninstall the driver.
    Keep us posted on this issue so that we can assist you better.
    Arun B J, May 6, 2021
  1. Bootcamp Slow Wifi Problem Changing Network Adapter Driver Wont Fix Either - Similar Threads - Bootcamp Slow Wifi
  2. Change/Improve/Update WİFİ NETWORK ADAPTER
    Change/Improve/Update WİFİ NETWORK ADAPTER: Hi,I have netwotk adapter which named "Intel® Centrino® Wireless-N 2230" so it gives 2.4 ghz wireless connection. Therefore ı want to upgrade my network adapter . I will remove the hardware which ı had and install the top model. I want to know that How can I find out which...
  3. Network Adapter / No Wifi Problem
    Network Adapter / No Wifi Problem: So, it was all good until one day I switched on and I can't connect to wifi. I have the cracked version of windows, I dont know if thats the problem, what I mean by the wifi not working is I cant find the icon, I clicked the notification bar and accessed it from there but it...
  4. Wifi Adapter Driver
    Wifi Adapter Driver: Hi, I recently reset my network settings because my wifi was havong too many problems, but now i cant find my network,it doesnt show any wifi names and the troubleshooter says problem with wifi adapter driver How can I fix this? Microsoft support have me on hold for an...
  5. Wifi problems in bootcamp
    Wifi problems in bootcamp: So i got windows installed in my mac and i have with my 5g internet being slow. Even though when I use my laptop i have hundred times the internet speed. This is the 5g internet with my mac with boot camp Ps. This is supposed to be in the bottom but i'm...
  6. Slow WiFi until Change Setting On Adapter. Then Eventually Slows Again
    Slow WiFi until Change Setting On Adapter. Then Eventually Slows Again: Hi All, I have a very weird problem and after some help if possible. I have a rock-solid 100Mbit cable connection and my laptop is only a couple of metres away from the wireless router. I check the speed at Speedtest by Ookla - The Global Broadband Speed Test and get an...
  7. "There might be a problem with the driver for the WiFi adapter"
    "There might be a problem with the driver for the WiFi adapter": I was using my Surface 7 Pro as usual this morning when suddenly my internet was not working. I went through the regular disconnect/connect, run troubleshoot, and even uninstalled my NordVPN app thinking there could be an issue with it. No luck. The network diagnostics gave...
  8. Reinstall or fix drivers for network adapters
    Reinstall or fix drivers for network adapters: Problem: Short: No connection to internet. Expanded: Purchased a refurbished Surface Laptop running on Windows 10. Arrived and started up on the 16th. Installed SIMS, game files, and transferred some photos and videos. Running fine until the 18th, when it would not connect...
  9. No internet/wifi. Network adapter problem.
    No internet/wifi. Network adapter problem.: [IMG] Hello all. Was wondering if I could get some help or opinions. I'm your average user, understand a bit but not an expert. The issue- Three week old Asus laptop X509UA running Win 10, everything going fine but turned on yesterday and no access to wifi/internet at all....
  10. Hosted WiFi network with Bootcamp?
    Hosted WiFi network with Bootcamp?: I use Win 10 with Bootcamp on my Macbook Pro. I need to create a WiFi network and the laptop as router. How can this be done in Win 10? Prompt netsh wlan show drivers reports that Hosted network is not supported, but the same network card supports it via macOS......
