Windows 10: Built-In Audio Device not showing up in all sound devices after BSOD and update
Discus and support Built-In Audio Device not showing up in all sound devices after BSOD and update in Windows 10 Software and Apps to solve the problem; 08/16/2024 My laptop had restarted and then updated. Before the update the audio devices/drivers were working fine, but after the update the audio... Discussion in 'Windows 10 Software and Apps' started by AR2_, Aug 15, 2024.
Built-In Audio Device not showing up in all sound devices after BSOD and update - Similar Threads - Built Audio Device
in Windows 10 GamingBuilt-In Audio Device not showing up in all sound devices after BSOD and update: 08/16/2024 My laptop had restarted and then updated. Before the update the audio devices/drivers were working fine, but after the update the audio devices didn't work and the driver for the built-in speaker did not appear in the "All Sound Devices" setting.... -
Sound not showing up in Device manager
in Windows 10 GamingSound not showing up in Device manager: I have an older vitalTEK 810R tablet that I got in 2016. I recently had to do a fresh install of windows 10 due to the OS got corrupted some how. Before I did this the sound worked and touch screen worked. Now neither work. Can someone point me in the direction to get drivers... -
in Windows 10 Software and AppsSound not showing up in Device manager: I have an older vitalTEK 810R tablet that I got in 2016. I recently had to do a fresh install of windows 10 due to the OS got corrupted some how. Before I did this the sound worked and touch screen worked. Now neither work. Can someone point me in the direction to get drivers... -
in Windows 10 Drivers and HardwareSound not showing up in Device manager: I have an older vitalTEK 810R tablet that I got in 2016. I recently had to do a fresh install of windows 10 due to the OS got corrupted some how. Before I did this the sound worked and touch screen worked. Now neither work. Can someone point me in the direction to get drivers... -
Bluetooth audio device not showing up as an audio device
in Windows 10 GamingBluetooth audio device not showing up as an audio device: Hi.I'm using Windows 11. So, I just tried pairing my Airpods Pro 1st gen and they connect but they don't show up as an audio device neither as an output or input and it doesn't show "Connected audio" like it did before. Tried with a JBL Go 2, same issue. Bluetooth adapter is... -
in Windows 10 Software and AppsBluetooth audio device not showing up as an audio device: Hi.I'm using Windows 11. So, I just tried pairing my Airpods Pro 1st gen and they connect but they don't show up as an audio device neither as an output or input and it doesn't show "Connected audio" like it did before. Tried with a JBL Go 2, same issue. Bluetooth adapter is... -
Headset not showing up in sound devices?
in Windows 10 GamingHeadset not showing up in sound devices?: My headset connects with a 3.5mm plug, I've used it before and it worked fine with the laptop, but now it just won't show as an available output device. I plug it in, I get the Realtek Audio Console popup asking which device I plugged in, I select headset, I hit okay, and... -
in Windows 10 Software and AppsHeadset not showing up in sound devices?: My headset connects with a 3.5mm plug, I've used it before and it worked fine with the laptop, but now it just won't show as an available output device. I plug it in, I get the Realtek Audio Console popup asking which device I plugged in, I select headset, I hit okay, and... -
All audio devices not working after update
in Windows 10 Ask InsiderAll audio devices not working after update: [ATTACH] After installing updates KB4552931 and KB4556799 and rebooting, all my audio output devices (motherboard, monitor, and VR headset) are not working with the status: Windows cannot start this hardware device because its configuration information (in the registry)...
