Windows 10: C drive is MBR and machine is UEFi, problem in using Aomei backup
Discus and support C drive is MBR and machine is UEFi, problem in using Aomei backup in Windows 10 Support to solve the problem; I tried to use Aomei backupper to do both system backup and disk backup of one of my machines, but neither of them is successful and there are error... Discussion in 'Windows 10 Support' started by Anthonywkho, Oct 21, 2020.
C drive is MBR and machine is UEFi, problem in using Aomei backup - Similar Threads - drive MBR machine
Recovery Drive an Aomei Backup Both Fail
in Windows 10 GamingRecovery Drive an Aomei Backup Both Fail: I am unable restore the XPS8940 with either a recovery drive or a system backup created by Aomei Backupper Pro. They start loading and then crash according to Aomei was because “ there is an invalid object in the boot configuration data store.” Dell SupportAssist cannot... -
in Windows 10 Software and AppsRecovery Drive an Aomei Backup Both Fail: I am unable restore the XPS8940 with either a recovery drive or a system backup created by Aomei Backupper Pro. They start loading and then crash according to Aomei was because “ there is an invalid object in the boot configuration data store.” Dell SupportAssist cannot... -
Recovery Drive & Aomei Backup Crash Log
in Windows 10 GamingRecovery Drive & Aomei Backup Crash Log: My computer is a Dell XPS8940 with Windows 11 Pro. The computer crashed as a result of trying to revert back to Outlook Classic. I am unable restore the XPS8940 with either a recovery drive or a system backup created by Aomei Backupper Pro. They start loading and then crash... -
in Windows 10 Software and AppsRecovery Drive & Aomei Backup Crash Log: My computer is a Dell XPS8940 with Windows 11 Pro. The computer crashed as a result of trying to revert back to Outlook Classic. I am unable restore the XPS8940 with either a recovery drive or a system backup created by Aomei Backupper Pro. They start loading and then crash... -
Add Windows drive with MBR to a UEFI System
in Windows 10 GamingAdd Windows drive with MBR to a UEFI System: Hi!I have a booteable hard disk by mean MBR with Windows Server 2019.I want to add that hard disk to a system with UEFI which has Linux installed with its boot loader /boot/efi partition.How can I add the Windows drive in order to get adual boot sistem?Thank you in advance... -
in Windows 10 Software and AppsAdd Windows drive with MBR to a UEFI System: Hi!I have a booteable hard disk by mean MBR with Windows Server 2019.I want to add that hard disk to a system with UEFI which has Linux installed with its boot loader /boot/efi partition.How can I add the Windows drive in order to get adual boot sistem?Thank you in advance... -
in Windows 10 Backup and RestoreC drive is MBR and machine is UEFi, problem in using Aomei backup: I tried to use Aomei backupper to do both system backup and disk backup of one of my machines, but neither of them is successful and there are error either after finishing the backup or when i checked the image files. Please see the screen shots below. [img] [img] I... -
Aomei backup
in Windows 10 Backup and RestoreAomei backup: I am trying Aomei backup. When I click on the disc backup it appears that both MBR and C:\ are included but the next step, even after adding the word add, seems to include only C:\. Does anyone know if this invisible MBR is included in the back up? I also would like to ask... -
UEFI or MBR ?
in Windows 10 Installation and UpgradeUEFI or MBR ?: I 'm making a bootable usb flash drive with Rufus to install Windows 10 as a dual boot with Windows 8.1. When I installed my new video card I had to disable safe boot and enable legacy support in the bios. When I make the bootable flash drive should I choose UEFI or MBR? 1969
