Windows 10: C drive is MBR and machine is UEFi, problem in using Aomei backup
Discus and support C drive is MBR and machine is UEFi, problem in using Aomei backup in Windows 10 Backup and Restore to solve the problem; I tried to use Aomei backupper to do both system backup and disk backup of one of my machines, but neither of them is successful and there are error... Discussion in 'Windows 10 Backup and Restore' started by Anthonywkho, Oct 23, 2020.
  1. C drive is MBR and machine is UEFi, problem in using Aomei backup
    I tried to use Aomei backupper to do both system backup and disk backup of one of my machines, but neither of them is successful and there are error either after finishing the backup or when i checked the image files. Please see the screen shots below.
    C drive is MBR and machine is UEFi, problem in using Aomei backup [​IMG]
    I suspect this may be due to the C drive (the disk) is MBR but my machine motherboard is running uefi, if this is the case, can you please help to resolve it.
    Thanks
    Anthony
  2. C drive is MBR and machine is UEFi, problem in using Aomei backup
    Thanks
    Anthony
  3. maranna Win User
    Aomei backup
    I am trying Aomei backup.
    When I click on the disc backup it appears that both MBR and C:\ are included but the next step, even after adding the word add, seems to include only C:\.
    Does anyone know if this invisible MBR is included in the back up?
    I also would like to ask if it is possible to run a disc backup without scheduling.
    And lastly, is the back up verified?
    Thank you
    maranna, Oct 23, 2020
  4. WildOne Win User
    Aomei backup
    A disk backup will backup the contents of the entire disk...you do not need to schedule backups (if schedule is checked, uncheck it) & the backup is not verified unless you have indicated so (menu, setting, other, check auto check backup). This will verify current and all future backups (recommended).
    WildOne, Oct 23, 2020
  1. C drive is MBR and machine is UEFi, problem in using Aomei backup - Similar Threads - drive MBR machine
  2. Recovery Drive an Aomei Backup Both Fail
    Recovery Drive an Aomei Backup Both Fail: I am unable restore the XPS8940 with either a recovery drive or a system backup created by Aomei Backupper Pro. They start loading and then crash according to Aomei was because “ there is an invalid object in the boot configuration data store.” Dell SupportAssist cannot...
  3. Recovery Drive an Aomei Backup Both Fail
  4. Recovery Drive & Aomei Backup Crash Log
    Recovery Drive & Aomei Backup Crash Log: My computer is a Dell XPS8940 with Windows 11 Pro. The computer crashed as a result of trying to revert back to Outlook Classic. I am unable restore the XPS8940 with either a recovery drive or a system backup created by Aomei Backupper Pro. They start loading and then crash...
  5. Recovery Drive & Aomei Backup Crash Log
  6. Add Windows drive with MBR to a UEFI System
    Add Windows drive with MBR to a UEFI System: Hi!I have a booteable hard disk by mean MBR with Windows Server 2019.I want to add that hard disk to a system with UEFI which has Linux installed with its boot loader /boot/efi partition.How can I add the Windows drive in order to get adual boot sistem?Thank you in advance...
  7. Add Windows drive with MBR to a UEFI System
  8. C drive is MBR and machine is UEFi, problem in using Aomei backup
    C drive is MBR and machine is UEFi, problem in using Aomei backup: I tried to use Aomei backupper to do both system backup and disk backup of one of my machines, but neither of them is successful and there are error either after finishing the backup or when i checked the image files. Please see the screen shots below. [img] [img] I...
  9. Aomei backup
    Aomei backup: I am trying Aomei backup. When I click on the disc backup it appears that both MBR and C:\ are included but the next step, even after adding the word add, seems to include only C:\. Does anyone know if this invisible MBR is included in the back up? I also would like to ask...
  10. UEFI or MBR ?
    UEFI or MBR ?: I 'm making a bootable usb flash drive with Rufus to install Windows 10 as a dual boot with Windows 8.1. When I installed my new video card I had to disable safe boot and enable legacy support in the bios. When I make the bootable flash drive should I choose UEFI or MBR? 1969
