Windows 10: can you keep power adap[ter plugged in with your battery connected too
Discus and support can you keep power adap[ter plugged in with your battery connected too in Windows 10 Performance & Maintenance to solve the problem; I have my battery in my laptop and I also have the power adapter plugged in at the same time. There are mixed opinions on the subject whether it kills... Discussion in 'Windows 10 Performance & Maintenance' started by MICHAELSARO, Nov 21, 2018.
  1. can you keep power adap[ter plugged in with your battery connected too
    I have my battery in my laptop and I also have the power adapter plugged in at the same time. There are mixed opinions on the subject whether it kills the battery or not . Some say once the battery reaches 100% the charging process shuts down. Battery doesn't kick in until power cord is removed. So the ac power adapter is the source of power not the battery. So flip a coin.
  2. DaveM121 Win User
    Plugged In, Not Charging
    Sometimes depending on your Windows 10 Build, your battery will not charge to 100%, this extends the life of your battery . . . plug out the laptop, drain the battery for 10 - 15 minutes, plug it back in and see if it starts to charge the battery
    If however, your battery is not charging at all in Windows 10, follow these steps to rectify this issue:
    • Disconnect Power Supply
    • Remove battery
    • Connect Power Supply
    • Turn on the laptop
    • Control Panel - Device Manager
    • Under the Batteries category, right-click all instances of Microsoft ACPI Compliant Control Method Battery , and Uninstall
    • Shutdown
    • Insert battery
    I Hope this Answers your Question!
    DaveM121, Nov 21, 2018
  3. windows 10 battery plugged in not charging (acer v11 touch)
    We appreciate that you already performed troubleshooting. On the other hand, we will be providing steps that seems to be the same with what you have done but with tweaks.
    If ever you encounter case wherein the laptop is plugged in but is not charging, we suggest that you try the following:
    • Disconnect the laptop’s power cable from the outlet/power source and laptop.
    • Turn off the laptop.
    • Remove the battery.
    • Reconnect the laptop’s power cable to the laptop then to the outlet/power source.
    • Power on the laptop.
    • Uninstall device of Microsoft ACPI-Compliant Control Method Battery
    • Turn off the laptop and then disconnect the power cable.
    • Insert the battery.
    • Reconnect the power cable.
    • Power on the laptop. Windows would then reinstall driver automatically.
    In case that the troubleshooting steps above didn’t help, our next step is update the driver if there is available update. You just have to go back to
    Device Manager > Batteries > Right click on Microsoft ACPI-Compliant Control Method Battery > Update Driver Software.
    Let me know if this works for you.
    JohnMel And, Nov 21, 2018
  4. DaveM121 Win User
    To resolve this issue, please follow these steps:
    • Unplug Laptop
    • Remove the Battery
    • Plug in Laptop and turn on the laptop
    • Go to Control Panel - Devices and uninstall all instances of Microsoft ACPI Compliant Control Method Battery
    • Shut down Laptop and unplug it
    • Insert Battery and plug in the laptop
    • Start the Laptop
    Hopefully this will work for you, please let us know!
  1. can you keep power adap[ter plugged in with your battery connected too - Similar Threads - keep power adap
  2. Can you set power to not charge battery when power lead is connected?
    Can you set power to not charge battery when power lead is connected?: Can you set power to not charge battery when power lead is connected? https://answers.microsoft.com/en-us/windows/forum/all/can-you-set-power-to-not-charge-battery-when-power/78cc6f96-d37e-4c8d-ac93-c3c2041971fb
  3. Can you set power to not charge battery when power lead is connected?
  4. Laptop crashed when plugged in on power with no battery plugged in
    Laptop crashed when plugged in on power with no battery plugged in: Hie . My laptop carshes every 5-10min when ever i am working on it. First is checked with The power is plugged in and the battery also it crashed. Then i removed the battery and connected directly to power plugged in it crashes again. Can anyone help me figure out what is the...
  5. Laptop crashed when plugged in on power with no battery plugged in
  6. Power mode plugged in and on battery?
    Power mode plugged in and on battery?: Which power mode do you guys use when a. your laptop is plugged in, b. when it's on battery? I usually use better performance when plugged in, because I suspect that best performance will lead to heat and to wear out the hardware faster. Am I right on that suspicion? Thanks...
  7. Power Management Battery/Plugged In
    Power Management Battery/Plugged In: Hi all, Just a quickie... does anyone know if its possible to set High Performance mode automatically when plugged in and then change this automatically to Balanced when unplugged? I seemed to think this was possible? 132404
  8. Power plugged in and effect on battery health
    Power plugged in and effect on battery health: Hello, What's the effect of plugging in laptop to power for 12 hours and above on the battery heath of laptop. Camillus. https://answers.microsoft.com/en-us/windows/forum/all/power-plugged-in-and-effect-on-battery-health/a8934347-b8c5-4bee-a00d-dda6422e77a6
  9. Battery Not Detected, but connected to laptop and plugged into power and not charging...
    Battery Not Detected, but connected to laptop and plugged into power and not charging...: I just purchased a brand new battery as the one I had before wasn't working. When I connected the battery to the laptop it's not detecting the battery so it won't charge the battery. How do I correct this issue?...
  10. Plugging in power adapter while battery is connected.
    Plugging in power adapter while battery is connected.: I have my battery in my laptop and I also have the power adapter plugged in at the same time. There are mixed opinions on the subject whether it kills the battery or not . Some say once the battery reaches 100% the charging process shuts down. Battery doesn't kick in until...
