Windows 10: Computer audio and drive port problems
Discus and support Computer audio and drive port problems in Windows 10 Drivers and Hardware to solve the problem; my computer audio sytem is not working, also my computer is not recognizing external Drives.... Discussion in 'Windows 10 Drivers and Hardware' started by julioniebla, Dec 7, 2019.
Computer audio and drive port problems - Similar Threads - Computer audio drive
Audio Ports not working???
in Windows 10 Software and AppsAudio Ports not working???: Hello,I built in the middle of October my PC and everything is running fine, the only problem is that it only recognises USB and HDMI audio devices. I tried everything with installing the Drivers of the manufacturer, checked the BIOS settings and even updated the BIOS to the... -
in Windows 10 Drivers and HardwareAudio Ports not working???: Hello,I built in the middle of October my PC and everything is running fine, the only problem is that it only recognises USB and HDMI audio devices. I tried everything with installing the Drivers of the manufacturer, checked the BIOS settings and even updated the BIOS to the... -
Audio ports not working
in Windows 10 GamingAudio ports not working: I've bought a used PC and on the first day of using it 5 days ago, the headphones I was using worked just fine. However, 3 days ago, my headphones stopped working. I thought it was just a headphone issue, so I plugged it into my phone, and it worked perfectly there. So I... -
in Windows 10 Software and AppsAudio ports not working: I've bought a used PC and on the first day of using it 5 days ago, the headphones I was using worked just fine. However, 3 days ago, my headphones stopped working. I thought it was just a headphone issue, so I plugged it into my phone, and it worked perfectly there. So I... -
Problems with my audio, USB ports and Bluetooth.
in Windows 10 Drivers and HardwareProblems with my audio, USB ports and Bluetooth.: My computer has no sound. It displays a red 'X' on the speaker sign at the lower right corner, and says no audio output devices installed. I have tried to update it but still it does not work. I have even tried to download another audio device but still no change. To the... -
in Windows 10 BSOD Crashes and DebuggingAudio ports not working: My headphones are not showing up in output. It used to show up as "NVIDIA High definition audio" but randomly NVIDIA HD audio switched to my monitor speakers. I think that my audio port for my headphones is broken or messed up. Any suggestions?[ATTACH]... -
audio drive problem
in Windows 10 Drivers and Hardwareaudio drive problem: I have troble with audio drive . i have below error Installed audio devices This file contains the details stored in the registry for all installed audio devices. File Name: Registry log.txt Collection information Computer Name: DESKTOP-88MT049 Windows Version: 10.0... -
problem with audio on my computer
in Windows 10 BSOD Crashes and Debuggingproblem with audio on my computer: since i installed the latest windows 10 have lost my audio. keeps telling me that there is no audio output device installed. can anyone help me please. The make is Intel Education Tablet, IntelR Atom TM X5-Z8350 CPU- 1.44GHZ : AUDIO- Intel SST audio devicewmd... -
Audio drive problems, is it be repaired?
in Windows 10 Drivers and HardwareAudio drive problems, is it be repaired?: Hi, thank you but wont it be impossible now as I can’t go online? Basically all I can do now is use the puter to charge my phone. Is there anything I can do to fix it offline? I can see previous version of windows in my temp files , is this something I can access? Press the...
