Windows 10: Computer not going into sleep mode when idle.I have tried from power management
Discus and support Computer not going into sleep mode when idle.I have tried from power management in Windows 10 Performance & Maintenance to solve the problem; I want to the PC to sleep I have changed the timing from 10 mins to 1 min but it does not go to sleep.I have updated my PC but still the problem... Discussion in 'Windows 10 Performance & Maintenance' started by Abhi_007dd, Apr 8, 2021.
Computer not going into sleep mode when idle.I have tried from power management - Similar Threads - Computer going sleep
Computer not going into sleep mode when idle, even after checking power management settings
in Windows 10 Performance & MaintenanceComputer not going into sleep mode when idle, even after checking power management settings: Hi! Our family laptop is not going into sleep mode when idle. It also sounds like it is processing something all the time even when not used. I already checked the power management options. Next, I used a diagnostics tool to pinpoint what it is that prevents the... -
in Windows 10 Performance & MaintenanceComputer not going into sleep mode when idle, even after checking power management settings: Hi! Our family laptop is not going into sleep mode when idle. It also sounds like it is processing something all the time even when not used. I already checked the power management options see attachment 1. Next, I used a diagnostics tool to pinpoint what it is that... -
Computer will not go into sleep mode
in Windows 10 Performance & MaintenanceComputer will not go into sleep mode: Please Help!!! My HP All In One 24-f0xx will not go into sleep mode by itself. The hard drive keeps running. If you select power then sleep that function works. I have updated all the drivers and changed the sleep mode option No Help. I have also ran SFC no issues found. In... -
in Windows 10 Performance & MaintenanceComputer will not go into sleep mode: Computer will not go into sleep mode. I have tried everything and adjusted everything and it will not sleep. The monitor does go into sleep mode, but the computer will not. I have adjusted all the settings in power and sleep section and nothing works. This just started a few... -
Computer is randomly going into sleep mode.
in Windows 10 CustomizationComputer is randomly going into sleep mode.: Event logs show it as user S-1-5-19, a non-named user account. Below is the event. This happens often. <EventID>1</EventID> <Version>3</Version> <Level>4</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x8000000000000000</Keywords> <TimeCreated... -
Computer turns off when going into sleep mode
in Windows 10 Performance & MaintenanceComputer turns off when going into sleep mode: I just recently started to have an issue of my computer turning off when going into sleep mode. When I turn it back on it takes over 3 minutes to come back to life. I have a copy of the event log but not sure how to post the file. Any help would be appreciated.... -
computer going into sleep mode,
in Windows 10 Performance & Maintenancecomputer going into sleep mode,: I have to reboot to fix. Lexapro PC goes black in the middle of working https://answers.microsoft.com/en-us/windows/forum/all/computer-going-into-sleep-mode/1b3ee20d-4486-45a2-a519-08daef97d341 -
Laptop going to sleep when idle (power options set to "Never")
in Windows 10 SupportLaptop going to sleep when idle (power options set to "Never"): When plugged in, this Toshiba laptop goes into sleep mode at roughly two minutes of idle time. When plugged in, I have the power options set to "Never". This just recently began occurring. Any ideas? 57465 -
When I lock my windows screen it tries to go in sleep mode.
in Windows 10 SupportWhen I lock my windows screen it tries to go in sleep mode.: I have a custom built PC (built last year) and recently when I lock my windows screen, after a few seconds it tries to go in sleep mode then it wakes itself up on its own then few seconds later it tries again. 1. I lock my screen 2. after i lock it, it brings me to my...
