Windows 10: CPU blocked at minimum speed after deactivating battery
Discus and support CPU blocked at minimum speed after deactivating battery in Windows 10 Drivers and Hardware to solve the problem; Hello everyone, I have a problem with my Asus TP300LA laptop and I was hoping someone might give me a hint. Recently it's charger controller went... Discussion in 'Windows 10 Drivers and Hardware' started by GustavoAlmeida, Dec 13, 2018.
CPU blocked at minimum speed after deactivating battery - Similar Threads - CPU blocked minimum
Deactivate low battery notification
in Windows 10 GamingDeactivate low battery notification: I have an old battery it works fine but this notification pops up anyone knows how to disable it on windows 11? https://answers.microsoft.com/en-us/windows/forum/all/deactivate-low-battery-notification/8db02dc3-764c-40cf-bb75-0709482b4af4 -
in Windows 10 Software and AppsDeactivate low battery notification: I have an old battery it works fine but this notification pops up anyone knows how to disable it on windows 11? https://answers.microsoft.com/en-us/windows/forum/all/deactivate-low-battery-notification/8db02dc3-764c-40cf-bb75-0709482b4af4 -
Low CPU Speed While Gaming on Battery Mode
in Windows 10 GamingLow CPU Speed While Gaming on Battery Mode: Hi, so the problem started recently on my laptop. My CPU speed when not gaming is around 2.3 GHz and above. However, whenever I play a game, my CPU clocks down to 0.79 GHz and stays there until I close the game. I also checked my temperature while gaming, which is around 60... -
in Windows 10 Software and AppsLow CPU Speed While Gaming on Battery Mode: Hi, so the problem started recently on my laptop. My CPU speed when not gaming is around 2.3 GHz and above. However, whenever I play a game, my CPU clocks down to 0.79 GHz and stays there until I close the game. I also checked my temperature while gaming, which is around 60... -
cpu speeds
in Windows 10 BSOD Crashes and Debuggingcpu speeds: I have an IntelR CoreTM i3-7130U CPU @ 2.70GHz 2.70 GHz on a dell laptop. my wife has a dell with amd a6-9225 radeon r4,5 compute cores 2c +3g 2.60 ghz. should they be about the same speed. her laptop is much slower.... -
Update error: minimum battery on a laptop with dead battery
in Windows 10 Installation and UpgradeUpdate error: minimum battery on a laptop with dead battery: Recently, onde of the updates failed error 0x8024004c, and the messege says that I need to have my battery charged at least 40%. Unfortunately, my PC's battery is dead, it doesn't charge anymore, and it only works while pluged. Is there any solution to make it update even... -
Cpu Speed
in Windows 10 BSOD Crashes and DebuggingCpu Speed: Hi everyone, I recently installed a fresh copy of windows 10 on my laptop, along with wiping my hard drive. Something I've notice however is that shortly after starting up, my CPU speed drops from around 3.50 ghz all the way down to 0.39 ghz, where it never fluctuates,... -
CPU speed
in Windows 10 BSOD Crashes and DebuggingCPU speed: How do I reduce my cpu speed from 100% to 65% to stop random freezing? https://answers.microsoft.com/en-us/windows/forum/all/cpu-speed/7e4c5137-0a24-4fd7-962d-d6180319a97e -
CPU speed at 0.48Ghz during low battery
in Windows 10 Performance & MaintenanceCPU speed at 0.48Ghz during low battery: Hi, On my laptop, I have noticed that the CPU speed is dramatically reduced from 1.98Ghz to 0.48Ghz whilst low on battery. As soon as I plug the laptop in, the CPU speed returns to 1.98Ghz. This loss of CPU speed has a great impact on system performance, rendering the...
cpu stuck at 0.48ghz
,cpu speed bloked
,cpu blocked lowest speed
