Windows 10: CPU speed throttling Maximum Processor State does not work anymore
Discus and support CPU speed throttling Maximum Processor State does not work anymore in Windows 10 Customization to solve the problem; First, I used the CPU speed limitation and system cooling policy=passive to keep down the fan noise. This worked fine, for a long time. But now I... Discussion in 'Windows 10 Customization' started by Blaubarschbube, Sep 30, 2020.
CPU speed throttling Maximum Processor State does not work anymore - Similar Threads - CPU speed throttling
Despite having 'Active' cooling policy with 'Minimum/Maximum processor states' at 100% CPU...
in Windows 10 BSOD Crashes and DebuggingDespite having 'Active' cooling policy with 'Minimum/Maximum processor states' at 100% CPU...: My processor works fine up to 100% when plugged in and the fan whirrs away happily. But when I unplug the laptop the processor utilisation cuts down to 15% and stays there until plugged in again, with the fan ceasing to run entirely. The above image shows the results of... -
in Windows 10 Software and AppsDespite having 'Active' cooling policy with 'Minimum/Maximum processor states' at 100% CPU...: My processor works fine up to 100% when plugged in and the fan whirrs away happily. But when I unplug the laptop the processor utilisation cuts down to 15% and stays there until plugged in again, with the fan ceasing to run entirely. The above image shows the results of... -
Advanced Power Plan Setting "Maximum Processor state" and "Minimum processor state" not...
in Windows 10 Ask InsiderAdvanced Power Plan Setting "Maximum Processor state" and "Minimum processor state" not...: SPECS: Win 10 (obv) i7 10700F 16GB 3000mhz 1660 Super So I used to set my processor states to prevent overheating, as my processor runs at 4.6 ghz, and only a few games can get it beyond what I like in terms of temp (80c+ or 176f+), as it generally rests around 80c/174f... -
Maximum processor state setting not working
in Windows 10 Ask InsiderMaximum processor state setting not working: Power options: Maximum processor state setting is not working *only* when laptop is plugged in. I set minimum and maximum to be 5% and 50% respectively for both plugged, and on battery. When it is on battery, CPU clock speed drops significantly but if I plug it in, there is... -
Windows 10 - Maximum Processor State isn't working
in Windows 10 Drivers and HardwareWindows 10 - Maximum Processor State isn't working: It was fine before when I'm still using Windows 7. Now it doesn't matter how much I limit my CPU max state, it always at 100% under load. Funny thing is, when I raise the minimum CPU state to higher than 5%, it works without issue. Perhaps this can help in some way :... -
in Windows 10 SupportWindows 10 - Maximum Processor State isn't working: It was fine before when I'm still using Windows 7. Now it doesn't matter how much I limit my CPU max state, it always at 100% under load. Funny thing is, when I raise the minimum CPU state to higher than 5%, it works without issue. Perhaps this can help in some way :... -
How to change the maximum processor state?
in Windows 10 BSOD Crashes and DebuggingHow to change the maximum processor state?: Hi all, I need to change the maximum processor state on my laptop Dell Inspiron 15 7559 and I do not have the option to under power settings. I've done everything that the other websites have told me but I still do not have the option to change this. Any help?... -
how to enable "maximum processor state"
in Windows 10 Customizationhow to enable "maximum processor state": I was trying to access the "maximum processor state" in the power options to adjust the percentage but found out that it's no longer visible. So I tried to follow guides on youtube and google to find a solution but to no avail. I was told by these guides to mess around with... -
Maximum processor state?
in Windows 10 SupportMaximum processor state?: Hi all, I'm not a techie so please bear with me. I just purchased a new laptop. HP with Windows 10 OS. AMD A6-9220 Dual-Core processor and 4 gig of ram. After it's initial setup and removing all the bloatware/crapware, most of the apps and disabling everything in the...
