Windows 10: Ctrl c+v keys and options on the right click does not work
Discus and support Ctrl c+v keys and options on the right click does not work in Windows 10 BSOD Crashes and Debugging to solve the problem; I've tried some steps that people have posted here in the community but none have worked, some of them:... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Andre Horacio, Jul 24, 2020.
  1. Ctrl c+v keys and options on the right click does not work
    https://answers.microsoft.com/pt-br...-e-colar/ea49301d-a705-43df-8871-f388c0515132
    https://answers.microsoft.com/pt-br...s/a77df8b2-34c5-447a-9241-f84b4675cd4f?page=1
    https://support.microsoft.com/pt-br...exe-does-not-work-if-session-was-disconnected
    https://thegeekpage.com/solved-fix-copy-paste-not-working-on-windows-10/
    None of the solutions I tried fixes the problem. The problem is with the ctrl c+v keys and also with the options on the right click, happens in the user profile or RDP sessions. When we reboot the machine, it works well for 20 minutes and then dies.
    This is happening on Windows 10 version 1803.
    Someone have any idea?
    Thank you in advance.
  2. skimpy123 Win User
    right side CTRL key does not work
    Thanks for your response. I've tried all the steps you've recommended and my problem has not been resolved.
    My computer is a Lenovo Ideapad P400 laptop so its not a stand alone keyboard. Right side ctrl key does not work on the on screen keyboard. Any other suggestions? Thanks.
    skimpy123, Jul 27, 2020
  3. AiruSun Win User
    Left ctrl -c v f a h x, none is working for the left ctrl key, but totally working for the right ctrl key
    Left ctrl -c v f a h x, none is working for the left ctrl key, but totally working for the right ctrl key. It's not a hardware
    problem, because ctrl + mouse scroll works for zooming out/in webpages. Used a second new keyboard, same thing.
    Tried the uninstalling keyboard drivers, didn't work. Please help! Thanks!
    AiruSun, Jul 27, 2020
  4. Ctrl c+v keys and options on the right click does not work
    ctrl + c ctr + v
    In Word 2007, copy and paste work only from the ribbon or right click. Although I have uninstalled the keyboard device and rebooted my pc it doesn't work with the shortcut keys: ctlr c, ctrl v, ctrl x (for the cut).
    andrea-p26, Jul 27, 2020
  1. Ctrl c+v keys and options on the right click does not work - Similar Threads - Ctrl c+v keys
  2. ctrl+c & ctrl-v not working
    ctrl+c & ctrl-v not working: hellorecently ctrl+c and ctrl+v have tended to stop working a lot, it's really annoying, i've tried most of what i can find on the internet after a while and nothing seems to be workingthings i've tried:-updating keyboard drivers-uninstalling keyboard drivers-ensuring that...
  3. ctrl+c & ctrl-v not working
  4. ctrl+c & ctrl-v not working
  5. CTRL+C or CTRL+V works only when both CTRL keys and C/V is pressed
    CTRL+C or CTRL+V works only when both CTRL keys and C/V is pressed: Hi, I accidently changed some settings for my CTRL keys on keyboard. Now, the common CTRL+C or CTRL+V are performed only when I press both CTRL keys +C or V. Both CTRL keys are working fine. I pressed some combination of ALT, CTRL and FN keys. Anyone knows the solution to go...
  6. CTRL+C or CTRL+V works only when both CTRL keys and C/V is pressed
  7. CTRL + C and CTRL + V Not working.
    CTRL + C and CTRL + V Not working.: Alright, so. My I can't copy things using CTRL + C and I can't paste things with CTRL + V. I do not have Microsoft word or any Office program on my PC. My keyboard is the HyperX Alloys Core RGB. I have tried resetting my keyboard FN + ESC for HyperX Alloys Core RGB . I have...
  8. CTRL + C and CTRL + V Not working.
  9. Ctrl C , Ctrl V Not Working
    Ctrl C , Ctrl V Not Working: So i was using my pc normally and for no reason my Ctrl C and Ctrl V stopped working i tried searching and someone told me to reinstall my keyboard driver and reset i did it and it worked for 5 seconds and after it stopped working again so i dont know what to do please help...
  10. Windows 10 - Ctrl C+V keys and options on the right click does not work
    Windows 10 - Ctrl C+V keys and options on the right click does not work: Hi folks, Based on some links address below, none of the possible solutions supported me to fix the problem: https://answers.microsoft.com/pt-br/windows/forum/all/windows-10-problemas-para-copiar-e-colar/ea49301d-a705-43df-8871-f388c0515132...
