Windows 10: Dell laptop running W10 doesn't see Surface running W10 on same home wifi. Surface sees Dell
Discus and support Dell laptop running W10 doesn't see Surface running W10 on same home wifi. Surface sees Dell in Windows 10 Network and Sharing to solve the problem; Dell laptop running W10 doesn't see Surface running W10 on same home wifi. Surface sees Dell... Discussion in 'Windows 10 Network and Sharing' started by BonnieWells2, May 31, 2019.
Dell laptop running W10 doesn't see Surface running W10 on same home wifi. Surface sees Dell - Similar Threads - Dell laptop running
W10 sees no mouse and keyboard
in Windows 10 Drivers and HardwareW10 sees no mouse and keyboard: Installed W10 from start on and face an often seen problem with mouse and keyboard not connected for Pin code entering. I have a KVM switch and on both multiboot PC's the problem is the same. I can use the KVM mouse and keyboard in BIOS, XP, W7, Linux, DVD and USB bootables... -
Program runs OK in W10 Pro but not in Home
in Windows 10 BSOD Crashes and DebuggingProgram runs OK in W10 Pro but not in Home: I created a few programs using gfortran in Windows 10 Pro, where they work well, but when I transferred the .exe files to my W10 Home laptop they all failed to start. I've tried a few ideas, such as compatibility with earlier Windows versions, but no success. Where should I... -
Help on running a VPN on W10 Home
in AntiVirus, Firewalls and System SecurityHelp on running a VPN on W10 Home: The laptop is set up to have two local accounts and an administrator account. I have Norton AV and VPN installed. When in the administrator account I can see Norton VPN in the hidden icon tray but it's not visible in the two local accounts. What I would like to get confirmed,... -
W10 Home PCs seeing only Win7 Pro & W10 Pro PCs on LAN, Not Home vers.
in Windows 10 Network and SharingW10 Home PCs seeing only Win7 Pro & W10 Pro PCs on LAN, Not Home vers.: I have a small Workgroup LAN (Ethernet) with one remaining Win 7 Pro PC (I would like to phase out), 2 - Win 10 Pro PCs, and a few Win 10 Home addition PCs. What I have noticed lately is when viewing the Network from the Win 7 Pro PC, ALL of the PCs in the network are... -
W10 seeing speakers and headphones as same device
in Windows 10 Drivers and HardwareW10 seeing speakers and headphones as same device: My old Surface Pro/W10 setup saw the speakers and headphone as separate things; so when I plugged in my headphones it would revert to the settings previously in use. So I used to have my speakers muted to avoid annoying colleagues with system sounds, then W10 would... -
Dell laptop running Windows 10 Home BSOD
in Windows 10 Performance & MaintenanceDell laptop running Windows 10 Home BSOD: My Dell Inspiron 15 is unable to get me to the login screen. It will sometimes turn on except for the scree which stays off, get me to the Dell logo screen and not load, or it will give me a BSOD with error code 0xc0000428, much like this:... -
My Laptop running W10.
in Windows 10 Installation and UpgradeMy Laptop running W10.: my laptop keeps trying to install updates. Error code 0x800F0908 which appears to be to with a device's I do not possess. Any responses. to *** Email address is removed for privacy ***. Regards.... -
So Why Doesn't W10 See this drive ?
in Windows 10 Drivers and HardwareSo Why Doesn't W10 See this drive ?: This may of just happened, but I'm not sure. I've been forcing myself to use W10 "System->Storage" to clean up my system. But I noticed a drive that is seen in "Disk Management", "Explorer" (and I can access it) but does not show in the new "System->Storage" display ? Some... -
Anyone here using dell inspiron 2020 came with W7 & is running w10?
in Windows 10 SupportAnyone here using dell inspiron 2020 came with W7 & is running w10?: Anyone here using dell inspiron 2020 that came with W7 & is running w10? Did you convert your drive to Guid Partition table (GPT), turn on secure boot and then install windows? If yes, did you have any problem with dell or other drivers with secure boot enabled? I...
