Windows 10: Desktop Right Click Personalize and Display Settings don't work
Discus and support Desktop Right Click Personalize and Display Settings don't work in Windows 10 Graphic Cards to solve the problem; I can successfully run Personalize and Display Settings from the PC Settings submenu. However, when I Right Click desktop, Personalize and Display... Discussion in 'Windows 10 Graphic Cards' started by silversmith, Oct 25, 2020.
  1. Desktop Right Click Personalize and Display Settings don't work
    I can successfully run Personalize and Display Settings from the PC Settings submenu. However, when I Right Click desktop, Personalize and Display Settings show up in the little menu, but do not work. I get a very brief CMD screen, then nothing. I have tried: Scannow and DISM clean, and removed the two HKLM and the HKCR registry items and the that are suggested online. I've updated graphics drivers. I've fully updated Windows 10 to ver1909. Any other suggestions to get this to work from Right Click desktop on my Lenovo AIO greatly appreciated.
    Many thanks.
    Peter
  2. Desktop Right Click Personalize and Display Settings don't work
    Many thanks.
    Peter
  3. Desktop Right Click Personalize and Display Settings don't work
    Many thanks for your efforts. Just to clarify: Display Settings and Personalize have been present in the desktop submenu all along. It's that clicking on them did nothing (except a momentary command screen). They work properly from the 'Settings" submenus. I'd like for them to work from the Right-Click desktop menu,
    I did all the steps you recommended, and they functioned as you predicted; thank you. I could run the reg files without permission error. After reboot, 'Display settings' was gone. I ran the 'Add Display' file, rebooted. Display Settings was back - But no joy - same no go as before.
    I ran the steps again. Everything in registry permissions was still as we left it before. I ran the Add Display file, rebooted. Still the same as before.
    What a bummer. If you have any further thoughts, I'd be grateful. Many thanks.
    Peter
  4. Desktop Right Click Personalize and Display Settings don't work
    Incidentally, other desktop shortcuts don't work either. Like Adjusting Date/Time by clicking on lower right time also gives momentary cmd screen and then nothing. But from PC Settings, it works. Perhaps a higher level failure for these desktop shortcuts to the settings is to blame. Any suggestions very much appreciated. Peter
  1. Desktop Right Click Personalize and Display Settings don't work - Similar Threads - Desktop Right Click
  2. Windows 10 right clicking personalization or display settings not working!
    Windows 10 right clicking personalization or display settings not working!: [ATTACH] submitted by /u/bricks2920 [link] [comments] https://www.reddit.com/r/Windows10/comments/iepa47/windows_10_right_clicking_personalization_or/
    Desktop Right Click Personalize and Display Settings don't work: I can successfully run Personalize and Display Settings from the PC Settings submenu. However, when I Right Click desktop, Personalize and Display Settings show up in the little menu, but do not work. I get a very brief CMD screen, then nothing. I have tried: Scannow and DISM...
  4. Getting error massage after doing right click - click on personalize or Display settings
    Getting error massage after doing right click - click on personalize or Display settings: [ATTACH][ATTACH] Hello, When I am trying to go into personalize or Display settings, getting an error message which I have uploaded. If someone knows about this problem kindly help me. Thanking you....
  5. Desktop Right Click not working
    Desktop Right Click not working: So when I try to right click my desktop to make a folder the blue loading icon loads and it takes about 5 minutes to load and then nothing happens. I do it again and it does the same thing.. when it's loading I can't click anything on my desktop at all and when it stops...
  6. Desktop Right Click not working
  7. Desktop Right Click not working
  8. Desktop Right Click not working
  9. Right click on desktop not working
    Right click on desktop not working: I just factory resetted my laptop and now when I right click on the desktop it only shows the loading icon but doesnt do anything, how can i fix it?...
  10. Right-clicking [on desktop] not working.
    Right-clicking [on desktop] not working.: I have downloaded Windows 10 as I am sure you all have. When I right-click [on a .jpg] on the desktop it takes ages to bring-up the context menu and invariably does NOT RESPOND [so my task manager tells me]. How do I fix this? 16837
