Windows 10: Device battery not detecting and login issue
Discus and support Device battery not detecting and login issue in Windows 10 Software and Apps to solve the problem; Hi, I accidentally pressed keys windows+ctrl+shift+B. After that my laptop is not detecting battery and not turning on without Charging plug. It also... Discussion in 'Windows 10 Software and Apps' started by anam saeed, Nov 7, 2024.
  1. Device battery not detecting and login issue
    Hi, I accidentally pressed keys windows+ctrl+shift+B. After that my laptop is not detecting battery and not turning on without Charging plug. It also shows a blinking orange charging light. And I also cannot login my device and device says wait for 2 hours. After 2 hours device turns on but whenever I turns off laptop and restart, it shows same error again. Plz help me to solve these issues.
  2. Battery Won't Charge Fully
    Step 1
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    Step 3
    FreeBooter, Nov 7, 2024
  3. Battery not detected (Unknown remaining)
    First of all I suggest you to try with a driver remove and reinstall with Device Manager. To do so:
    1. Press WINDOWS + X
    2. Click on "Device Manager"
    3. Click on "Battery"
    4. Right click on the first element on list
    5. Click on "Remove"
    6. Repeat steps 4 and 5 for the second element on list
    7. Click on "Detects Hardware change" (monitor icon)
    Then reboot your system and check if the problem still exists.
    Please tell me if the solution works.
    StefanoTamiotti, Nov 7, 2024
  4. Device battery not detecting and login issue
    Surface Pro 4 Battery issues
    If the laptop works without the battery than the charger is functioning correctly. Take a cloth with a bit of rubbing alcohol on it (or some on-the-go alcohol swabs), and clean the metal contacts that connect your battery to your laptop.
    Install the latest versions of your laptop device drivers you can download the latest device drivers from the device manufacturer or from your laptop manufacturer website.
    Step 1
    6. Under the Batteries category, right-click all the Microsoft ACPI Compliant Control Method Battery listings, and select Uninstall (it’s ok if you only have 1).
    If above suggestions won't resolve the battery charge issue then follow below steps.
    Step 2
    3. Start the laptop with only AC adapter connected to the laptop.
    4. When you log in to Windows OS connect the battery while Windows OS working.
    Step 3
    Hopefully one of the above suggestions will help you resolve the battery not charging problem. If the battery still doesn't charge, you may need to replace your battery.
  1. Device battery not detecting and login issue - Similar Threads - Device battery detecting
  2. Device battery not detecting and login issue
    Device battery not detecting and login issue: Hi, I accidentally pressed keys windows+ctrl+shift+B. After that my laptop is not detecting battery and not turning on without Charging plug. It also shows a blinking orange charging light. And I also cannot login my device and device says wait for 2 hours. After 2 hours...
  3. No battery is detected
    No battery is detected: So i was using a Toshiba laptop with new battery and when i plug it in the orange led wont lit up, however i was in the taskbar and saw “No battery is detected and it shuts off when unplugged however the battery is inserted when i plug it in the white led near the plug lits...
  4. Battery level detection issue.
    Battery level detection issue.: I have an inspiron 3542 laptop with i3-4030u and intel hd graphics 4400. OS is windows 10 pro version 22h2. I am having battery level detection issues. This laptops battery has actually been repaired once and now it won't correctly detect battery level. Even at the moment of...
  5. Battery level detection issue.
  6. Battery level detection issue.
  7. Battery not detected
    Battery not detected: Hello, I have an ASUS A43E laptop and encountered some problems. It hasn’t been used for a few months, and when I started it up a few days ago, it would not turn on if I did not have it plugged in and the battery was at 0%.It did however seem like it was charging; so I just...
  8. no battery detected
    no battery detected: i am having a problem, laptop is saying no battery detected. i have tried everything i can see or think of. can anyone help https://answers.microsoft.com/en-us/windows/forum/all/no-battery-detected/43b1ddff-35cb-4620-ab1c-c6dcab5f4079
  9. battery not detected
    battery not detected: my hp pavilion dv4 battery cannot be detected. I have tried new replacement but still cant be detected https://answers.microsoft.com/en-us/windows/forum/all/battery-not-detected/f5bc6810-1381-459e-b287-67e4f0642919
  10. no battery is detected
    no battery is detected: why do I get this when clicking on the battery icon? sometimes my pc will not turn on because it does not detect its own battery. https://answers.microsoft.com/en-us/windows/forum/all/no-battery-is-detected/b6a23c37-77d4-4ba0-bc0f-05b6bd256675
