Windows 10: Different VGA max resolution and HDMI max, Sony TV
Discus and support Different VGA max resolution and HDMI max, Sony TV in Windows 10 Graphic Cards to solve the problem; Hello! Probably this is normal, but I want to ask just in case. I am using a Sony Bravia KDL-19L4000 19" LCD TV (see my specs) as a monitor. At first... Discussion in 'Windows 10 Graphic Cards' started by spapakons, Mar 9, 2020.
Different VGA max resolution and HDMI max, Sony TV - Similar Threads - Different VGA max
Max resolution via Miracast
in Windows 10 GamingMax resolution via Miracast: Hello, I am trying to connect my surface book 3 Quadro RTX 3000 via nativ wireless display to my Samsung Q80 QLED TV. However, when i extend the displays it doesnt support 4K on the wireless display Max supported is 2560x1600, but that leaves bars on the side so i used... -
in Windows 10 Software and AppsMax resolution via Miracast: Hello, I am trying to connect my surface book 3 Quadro RTX 3000 via nativ wireless display to my Samsung Q80 QLED TV. However, when i extend the displays it doesnt support 4K on the wireless display Max supported is 2560x1600, but that leaves bars on the side so i used... -
Max
in Windows 10 Drivers and HardwareMax: A customer claims their Sound Card is no longer working after a major Windows Feature Update from 1803 to 1809, what can you do to get their sound working again? https://answers.microsoft.com/en-us/windows/forum/all/max/58cfa3ee-2e05-45b8-874b-b5a3b839d75d -
Monitor Wont go to Max Resolution
in Windows 10 BSOD Crashes and DebuggingMonitor Wont go to Max Resolution: Hello, I was using two monitors, 1 display was 1440 x 900 but theres no problem with that display. The 2nd display how ever wont go to its max resolution. The second monitor is an older prehistoric 4:3 monitor which can reach up to 1280x1024 but I woke up today and found out... -
Max resolution on external screen?
in Windows 10 Graphic CardsMax resolution on external screen?: I have a laptop (HP ProBook x360 440 G1 4QW71EA 2in1 Notebook i7-8550U Full HD SSD Win10 Pro) and wanted to ask how I could read out what maximum resolution it could do if I connected a monitor. For example a 4K monitor. Thanks! :)... -
1600 x 900 Max. Resolution
in Windows 10 Customization1600 x 900 Max. Resolution: After upgrading my desktop PC from Windows 7 to 10, I couldn't find a setting to match my 1600 x 900 max. resolution monitor ACER X203H. How can I adjust the settings so my monitor display isn't skewed?... -
Recomended (and max) Resolution is too small
in Windows 10 CustomizationRecomended (and max) Resolution is too small: My computer monitor's resolution is 1680 x 1050 and windows has always accepted that. However, I recently bought a new a monitor from a thrift store. I don't have any extra cords for a dual monitor setup but I wanted to at least check if it worked. I unplugged the cord from... -
Laptop max resolution less than projectors
in Windows 10 Graphic CardsLaptop max resolution less than projectors: My camera club has just bought a new Projector with a 1920x1200 max resolution, but the clubs Windows laptop screen is only 1920x1080 as is the max graphics card resolution.How can we get the laptop to project at the Projectors max resolution of 1910x1200, or can’t we? Have... -
Windows update is changing screen max resolution
in Windows 10 Drivers and HardwareWindows update is changing screen max resolution: Over the last few months there have been multiple Windows 10 updates from Microsoft that change the maximum possible resolution of my 4K Samsung U24E590D monitor (connected via HDMI) from it's supported maximum of 4096x2160 back to 1920x1200 and there is nothing I can do to...
