Windows 10: "Disconnecting" Issue with Airpods (and other bluetooth audio devices)
Discus and support "Disconnecting" Issue with Airpods (and other bluetooth audio devices) in Windows 10 Ask Insider to solve the problem; I've been experiencing issues very similar to the ones experienced by another user in the following post:... Discussion in 'Windows 10 Ask Insider' started by /u/eeyeehee, Dec 1, 2020.
"Disconnecting" Issue with Airpods (and other bluetooth audio devices) - Similar Threads - Disconnecting Issue Airpods
Audio issues with Bluetooth connected devices
in Windows 10 GamingAudio issues with Bluetooth connected devices: I have had this issue with many productsThose beings Beats Solo 3 and Samsung Airbuds.Basically anytime I try to use either of them for audio and mic they will not work.Not only that I have to go through a 10 minute process resetting things and even to the point of... -
in Windows 10 Drivers and HardwareAudio issues with Bluetooth connected devices: I have had this issue with many productsThose beings Beats Solo 3 and Samsung Airbuds.Basically anytime I try to use either of them for audio and mic they will not work.Not only that I have to go through a 10 minute process resetting things and even to the point of... -
Bluetooth Issue on my Audio Device?
in Windows 10 GamingBluetooth Issue on my Audio Device?: Hi...what the hell is going on with WIndows 11?? I have an annoying issue with my Audio Bluetooth device. I have Oppo, realme and the new one is Lenovo ANC Headphone. None of them was working after the Windows 11 update!!! the worst part is i cannot undo the update back to... -
in Windows 10 Software and AppsBluetooth Issue on my Audio Device?: Hi...what the hell is going on with WIndows 11?? I have an annoying issue with my Audio Bluetooth device. I have Oppo, realme and the new one is Lenovo ANC Headphone. None of them was working after the Windows 11 update!!! the worst part is i cannot undo the update back to... -
Bluetooth keeps disconnecting from my Airpods
in Windows 10 Drivers and HardwareBluetooth keeps disconnecting from my Airpods: Hi,I would like to request help for fixing the bluetooth disconnection from my Airpods. The connection worked for 2 weeks after I purchased my current laptop however in my 3rd week, I noticed that my Bluetooth kept flickering from connected to disconnected. I have tried... -
Audio Bluetooth Device connecting as 'Other Device'
in Windows 10 Drivers and HardwareAudio Bluetooth Device connecting as 'Other Device': Hi, I've just bought a pair of Cambridge Audio Melomania Wiress Headphones. I'm trying to connect them via Bluetooth to my Windows Surface 4. The headphones are connecting but as an 'Other Device' so I'm not able to use them as an audio device. How can I change this so... -
Bluetooth Audio Devices Disconnect When Playing Audio
in Windows 10 Drivers and HardwareBluetooth Audio Devices Disconnect When Playing Audio: Issue Description: After pairing my audio device it shows as connected in the Bluetooth settings. When I tab out of settings and play audio, the Bluetooth device disconnects neither bluetooth nor the audio device is turned off, the device just disconnects. Sometimes the... -
Stop audio device disconnecting? (Silly issue...)
in Windows 10 Drivers and HardwareStop audio device disconnecting? (Silly issue...): Hi, my PC is connected from my Nvidia 1080 Ti to a soundbar by HDMI. Soundbar then passes video through to my TV. I don't have any audio issues when everything is turned on. I've just updated to 1909 and haven't seen this issue before. If the soundbar turns off, once I turn... -
Bluetooth headphones connected as other devices not audio.
in Windows 10 Drivers and HardwareBluetooth headphones connected as other devices not audio.: When I try and connect my Bluedio headphones to my Windows 10 pc through a generic USB bluetooth connector everything goes as planned and the headphones connect and pair initially as an audio device and then jumps to "other device"...of course I am getting no sound. Device...
