Windows 10: [Discussion] USB Suspend Settings / USB Power Management are problematic
Discus and support [Discussion] USB Suspend Settings / USB Power Management are problematic in Windows 10 Ask Insider to solve the problem; I just got a new PC with fresh settings about two month ago. Thinking fresh system should have no issue on most of the thing, I naively plug my old... Discussion in 'Windows 10 Ask Insider' started by /u/notyourkindofcat, Nov 26, 2020.
  1. [Discussion] USB Suspend Settings / USB Power Management are problematic
    I just got a new PC with fresh settings about two month ago. Thinking fresh system should have no issue on most of the thing, I naively plug my old keyboard (a MKA-3C) into the new PC.
    Before anything, the keyboard has no issue on the old PC, even with the keyboard RGB light on.
    Now, whenever I am typing, some key will not register occasionally, followed by a a device disconnect -> device connect sound.
    To make sure it wasn't the keyboard being faulty, I plug back to the old PC and uses it for couple few days, the keyboard never disconnect on the old PC (Old PC is also a Win10).
    After some googling, it appears to be a power management issue :https://pocketables.com/2016/04/fix-windows-10-keyboard-disconnecting.html
    So I did :
    1. In power setting, disable all USB selective suspend settings.
    2. Make sure PC is on high performance mode.
    3. In EVERY USB settings inside device manager, untick allow computer to turn of this device to save power.
    4. Reinstall the Generic USB Hub driver.
    5. Go into registry / power config via cmd to ensure the power profile have the correct "USB selective suspend settings"
    This solution worked for many people, unfortunately, this doesn't work on my new PC. I can still hear disconnection sound for nearly every minutes, and a few keystroke will not register. I can however, off the RBG light on the keyboard, the disconnection is less frequent, but I am still getting them. This is not tolerable during gaming, it is also not tolerable during coding.
    Now, a few question to Microsoft people :
    1. Is there event logger / event viewer setting to tell WHICH devices are frequently turned off / on - there are logs when you INSTALL a new device, but not via disconnecting?
    2. Why is it so persistent and power down my USBs and disrespect to the settings?
    and also to everyone who might experienced in this. Is there potential solution I might be missing out to try to get rid of the issue? Get rid of existing keyboard could be one of it, but I cant be sure the next keyboard doesn't have this issue.
    submitted by /u/notyourkindofcat
    [link] [comments]
  2. Guru-# Win User
    USB settings in Power Plan Options on Windows 10 is missing, how to restore it?
    As per the below suggested steps I am trying to disable the USB in USB selective suspend setting in my Dell laptop with Windows 10 Home. however, I do not find the USB Settings at all in two modes Balanced mode or Dell (Active) mode under change advanced
    power settings. How to restore it?
    USB Selective Suspend Settings, follow the steps below:
    1. Press Windows + X.
    2. Choose Power Options.
    3. Select Choose when to turn off the display.
    4. Open Change advanced power settings.
    5. Expand USB settings and USB selective suspend setting.
    6. Select Enabled (default) or Disabled.
    7. Click Apply, then OK.
    Guru-#, Nov 26, 2020
  3. USB selective suspend settings not available?
    Hello Grant,
    To answer your question about USB Selective Suspend Settings, follow the steps below:
    • Press Windows + X.
    • Choose Power Options.
    • Select Choose when to turn off the display.
    • Open Change advanced power settings.
    • Expand USB settings and USB selective suspend setting.
    • Select Enabled (default) or Disabled.
    • Click Apply, then OK.
    Please check out the image below for your reference:
    [Discussion] USB Suspend Settings / USB Power Management are problematic 1f6ab742-6b2f-4cb8-ae34-a5db8caa86d8.png
    Keep us informed about the outcome.
    Edjay Rust, Nov 26, 2020
  4. [Discussion] USB Suspend Settings / USB Power Management are problematic
    USB HUB
    Incompatible USB hub driver is one of the possible reasons why this issue is happening. We recommend uninstalling the USB Root Hub driver and see if it helps. Follow the stepes below:
    • Open Device Manager.
    • Double-click Universal Serial Bus controllers to expand.
    • Right-click USB Root Hub, then click Properties.
    • Go to the Driver tab.
    • Click Uninstall.
    • Restart your computer.
    Note: Restarting your computer will automatically reinstall a generic driver for your computer. Also, we suggest connecting your USB hub while performing the steps.
    If the issue still persists, let's disable the USB selective suspend settings thru Power Options to resolve the issue. Follow the steps below:
    • Type Power Options in the search box, then press Enter.
    • Locate USB settings > USB selective suspend settings.
    • Select Disable.
    Keep us in the loop with the result.
    Martin Bar, Nov 26, 2020
  1. [Discussion] USB Suspend Settings / USB Power Management are problematic - Similar Threads - Discussion USB Suspend
  2. USB Power Setting not saving
    USB Power Setting not saving: I have a PC that continues to turn off the USB touch response of a touch screen. I go to the Device Manager > Universal Serial Bus controllers I uncheck every "Allow the computer to turn off this device to save power" The next day, after being turned off overnight, one or...
  3. USB Power settings - WHY!???
    USB Power settings - WHY!???: OK a little bit of a rant and reporting and issue that should never have happened. This happened to my son who depends on things like live streaming for his income as a professional musician. I'm a former MSFT consultant and assisted with this troubleshooting over a the...
  4. Settings Suspended in Task Manager
    Settings Suspended in Task Manager: In the task manager, several Processes (e.g. Settings and Cortana) are labeled "suspended" and then there's a leaf icon or something next to it. What is this? How do I stop this?...
  5. USB Selective Suspend
    USB Selective Suspend: I've got an issue with selective suspend of a thermal printer in Windows 10 and I can't seem to find anywhere that specifically states the length of time Windows will wait. Any chance there's a simple answer for this? I'm able to disable it entirely, but it seems weird that...
  6. USB Selective Suspend is not working
    USB Selective Suspend is not working: Greetings all, Long story short: No matter how many USB options I check in device manager (properties > power management > allow the computer to turn off this device to save power), and no matter how many Advanced power plan settings I adjust the USB selective...
  7. USB Selective Suspend is not working
  8. Windows10 - USB HUB Power Management
    Windows10 - USB HUB Power Management: Hi, I've seen the problem same Jeff mentioned below on the latest Windows10 version when I plug USB flash drive to the HUB that use USB2412 chip. (No issue found if direct plug to the host PC). You can see post from Jeff on below link: One solution that I've tried and...
  9. Adjust USB selective suspend setting
    Adjust USB selective suspend setting: I think this is a long shot but here goes.... I know how to turn off/on the "USB selective suspend setting". I actually don't mind that it is enabled however what I find annoying is when my external 'wakes', a window pops up showing all of my files on the external as if I...
  10. Remove 'USB selective suspend setting' in Power Options in Windows
    in Windows 10 Tutorials
    Remove 'USB selective suspend setting' in Power Options in Windows: How to: Remove 'USB selective suspend setting' in Power Options in Windows How to Add or Remove "USB selective suspend setting" from Power Options in Windows The Power Options allows users to specify whether USB selective suspend is turned on or off. The USB...
