Windows 10: Does power mode change to Best power efficiency after I turn on the battery saver?
Discus and support Does power mode change to Best power efficiency after I turn on the battery saver? in Windows 10 Gaming to solve the problem; Does power mode change to Best power efficiency after I turn on the battery saver? Or do I have to manually change it myself?... Discussion in 'Windows 10 Gaming' started by yangyangyang1, Mar 29, 2023.
Does power mode change to Best power efficiency after I turn on the battery saver? - Similar Threads - Does power mode
BSOD only WHEN USING Best Power efficiency mode
in Windows 10 Software and AppsBSOD only WHEN USING Best Power efficiency mode: My laptop is an Asus TUF A15—Ryzen 7 CPU, 16GB RAM, rtx 3050TI card. I was having non-stop BSOD and reinstalled Windows a few times windows 11 Home Last time I didn't install the ROG Armory crate. Now I do not get BSOD when my laptop is plugged in. Unless I use Best Power... -
why my power mode changes into power efficiency mode automatically?
in Windows 10 Performance & Maintenancewhy my power mode changes into power efficiency mode automatically?: why my power mode changes into power efficiency mode every time i pluge in for charging my laptop i choose it to balanced but it automatically changes in to power efficiency mode.... -
in Windows 10 Gamingwhy my power mode changes into power efficiency mode automatically?: why my power mode changes into power efficiency mode every time i pluge in for charging my laptop i choose it to balanced but it automatically changes in to power efficiency mode.... -
in Windows 10 Software and Appswhy my power mode changes into power efficiency mode automatically?: why my power mode changes into power efficiency mode every time i pluge in for charging my laptop i choose it to balanced but it automatically changes in to power efficiency mode.... -
in Windows 10 Software and AppsDoes power mode change to Best power efficiency after I turn on the battery saver?: Does power mode change to Best power efficiency after I turn on the battery saver? Or do I have to manually change it myself? https://answers.microsoft.com/en-us/windows/forum/all/does-power-mode-change-to-best-power-efficiency/d80fc87e-70b3-4c96-8167-e8b0ced2f8f2 -
Best power efficiency VS power saving mode.
in Windows 10 GamingBest power efficiency VS power saving mode.: Hello. Most of the time I use my laptop for browsing and PDF reading and these activities doesn't require much performance so most of the time my power mode is set to power saving mode. But int the power mode there is another option which is " Best power efficiency ". So, in... -
in Windows 10 Software and AppsBest power efficiency VS power saving mode.: Hello. Most of the time I use my laptop for browsing and PDF reading and these activities doesn't require much performance so most of the time my power mode is set to power saving mode. But int the power mode there is another option which is " Best power efficiency ". So, in... -
Power Mode Battery Saver
in Windows 10 CustomizationPower Mode Battery Saver: I wanted to know little deep about how battery saver option works and how much energy it saves within an hour considering the laptop is brand new. https://answers.microsoft.com/en-us/windows/forum/all/power-mode-battery-saver/a2c0a78b-544f-45fa-84c9-eca023caaf35 -
Battery Saver and Power saving
in Windows 10 CustomizationBattery Saver and Power saving: Should i change power slide to better performance or best performance while gaming ? if i am not wrong, power saver on windows 7 reduced cpu speed and it was bad for games. BUT new power slide mode (battery saver, better battery, etc.) affects to computer speed or game...
