Windows 10: Double Left Click problem.
Discus and support Double Left Click problem. in Windows 10 Ask Insider to solve the problem; Whenever I am dragging files or playing something like Kerbal Space Program where it requires a shit ton of left click crescendo like the maneuver... Discussion in 'Windows 10 Ask Insider' started by /u/Dove_Agency, Aug 6, 2020.
Double Left Click problem. - Similar Threads - Double Left Click
Files / text are deleted when I left click / double left click
in Windows 10 GamingFiles / text are deleted when I left click / double left click: A few weeks back my files began being deleted when I left click on their icons in my desktop / file explorer.Some times all files under a folder are deleted, if I click in the file list part of the file explorer. When that happens, if I click on the cancel button my click is... -
in Windows 10 Software and AppsFiles / text are deleted when I left click / double left click: A few weeks back my files began being deleted when I left click on their icons in my desktop / file explorer.Some times all files under a folder are deleted, if I click in the file list part of the file explorer. When that happens, if I click on the cancel button my click is... -
in Windows 10 Network and SharingFiles / text are deleted when I left click / double left click: A few weeks back my files began being deleted when I left click on their icons in my desktop / file explorer.Some times all files under a folder are deleted, if I click in the file list part of the file explorer. When that happens, if I click on the cancel button my click is... -
Double click problem
in Windows 10 Software and AppsDouble click problem: I have this mouse for my desktop and it is connected by a cable. Today double click function not working. I need to right click to open files. I tried to use different mouse using cable as well and it works fine. I used the problem mouse to different device and it works fine... -
in Windows 10 Drivers and HardwareDouble click problem: I have this mouse for my desktop and it is connected by a cable. Today double click function not working. I need to right click to open files. I tried to use different mouse using cable as well and it works fine. I used the problem mouse to different device and it works fine... -
in Windows 10 GamingDouble click problem: I have this mouse for my desktop and it is connected by a cable. Today double click function not working. I need to right click to open files. I tried to use different mouse using cable as well and it works fine. I used the problem mouse to different device and it works fine... -
Microsoft arc mouse - left click randomly behaves as double click
in Windows 10 Drivers and HardwareMicrosoft arc mouse - left click randomly behaves as double click: From the last 2 weeks, my Microsoft Arc mouse latest surface version is behaving crazy with my Lenevo E480 Windows 10 laptop. I have tried reducing the speed of double click from the mouse & pointer settings. Still issue persist. Request Microsoft to please look into it if... -
Weak Left Double Click
in Windows 10 BSOD Crashes and DebuggingWeak Left Double Click: Single left clicks seem to work fine, but when I double click something, I usually have to double click something several times to highlight or open something. Can anyone help?... -
Left Click & double tap not working in windows 10!
in Windows 10 SupportLeft Click & double tap not working in windows 10!: Hello, I use a HP laptop & since the last few days I am not able to open any files or click on something since the left (main) key & double tap on the mouse pad are not working! Although I am able to move the cursor/pointer over the touch pad & the right click is working fine...
