Windows 10: Downgrade firmware for Wireless Display Adapter v2 note download firmware not driver
Discus and support Downgrade firmware for Wireless Display Adapter v2 note download firmware not driver in Windows 10 Software and Apps to solve the problem; Hi, how can i downgrade the firmware not not the driver as been responded on the so many questions on forum, i want to revert firmware to first... Discussion in 'Windows 10 Software and Apps' started by RúbenCarneiro, May 20, 2022.
  1. Downgrade firmware for Wireless Display Adapter v2 note download firmware not driver
    Hi, how can i downgrade the firmware not not the driver as been responded on the so many questions on forum, i want to revert firmware to first release.
  2. Graeme.P Win User
    How to downgrade the firmware of the Wireless Display Adapter
    Hi SunnyYu, thanks for your question. I'm Graeme, a Microsoft Community expert and fellow user.
    I don't know of any way to revert to a previous firmware version for the Microsoft Wireless Display Adapter.
    Probably the best thing to do with the one that isn't working correctly would be to try to troubleshoot the problem on the current firmware version.
    Here's a Microsoft Support article that'll help you troubleshoot the adapter:
    https://support.microsoft.com/en-au/help/403489...
    You could also try reinstalling your Windows drivers for the adapter.
    - Press Windows Key+X and choose Device Manager.
    - Find your Wireless Display Adapter in the list.
    - Right-click it and choose Update Driver.
    - If that doesn't work, try uninstalling it and then scan for hardware changes to reinstall the driver.
    Let me know how you go! Thanks!
    Graeme.P, May 20, 2022
  3. SunnyYu Win User
    We have two Microsoft Wireless Display Adapters and one of the firmware version is V.2.0.8350. and another one is V.2.8381
    But the higher version Adapter cannot display very well, always cannot display completely. And the lower version one is working well.
    Could you please advise the correct way to downgrade the version to the lower one?
    Thanks.
    SunnyYu, May 20, 2022
  4. Downgrade firmware for Wireless Display Adapter v2 note download firmware not driver
    Microsoft Wireless Display Adapter - How to downgrade Firmware Version 1.3.8305 to 1.2.x
    MS Team,
    Narrowed down the problem. For some reason, the 1920 * 1080 resolution refresh rate on Wireless Display Adapter is set to 30 Hz
    on Firmware 1.3.8305, but in firmware 1.2.x the refresh rate is at 59 Hz.
    Verified it on another Display Adapter whose firmware is not upgraded.
    How can I downgrade the firmware from 1.3.8305 to 1.2.x.?????
    Vasuki
    ----- Originally Identified and Reported Problem --------
    Hi MS Team,
    Just got the Wireless Display Adapter, works like charm on Dell Inspiron with WiDi and Samsung phone. The Microsoft Wireless Display Adapter app on Win10 did a firmware upgrade from 1.2.x to 1.3.x Series. Post that connected my OnePlus Two with Lolipop 5.1.1,
    Refresh Rate problems, the Screen does not refresh like the PC or Samsung Note 3 Neo phone. Help Please.
    Is there a way to reset the Microsoft Wireless Display Adapter.
    Vasuki Narayan, May 20, 2022
  1. Downgrade firmware for Wireless Display Adapter v2 note download firmware not driver - Similar Threads - Downgrade firmware Wireless
  2. Is there offline drivers and firmware for wireless display adapter model:1733.
    Is there offline drivers and firmware for wireless display adapter model:1733.: I am looking for a offline installer for drivers and firmware to support my units wireless hdmi display adapters that we use for our classroom projectors. We got new surface pro's and they don't have the drivers needed to connect to the adapters. We do not have the option to...
  3. Is there offline drivers and firmware for wireless display adapter model:1733.
  4. Is there offline drivers and firmware for wireless display adapter model:1733.
  5. Downgrade firmware for Wireless Display Adapter v2 note download firmware not driver
    Downgrade firmware for Wireless Display Adapter v2 note download firmware not driver: Hi, how can i downgrade the firmware not not the driver as been responded on the so many questions on forum, i want to revert firmware to first release....
  6. Downgrade firmware for Wireless Display Adapter v2 note download firmware not driver
  7. No Audio After Firmware Update - Microsoft Wireless Display Adapter
    No Audio After Firmware Update - Microsoft Wireless Display Adapter: Hello. I'm quite vexed by this issue, and wish there were a way to downgrade the firmware on my MWDA. I have the adapter plugged into an HDMI port on my TV a 1080p set. Previously, I had no trouble with audio or video. Everything worked great. The setup I'm using is I have...
  8. Choosing files to download for Drivers and Firmware
    Choosing files to download for Drivers and Firmware: I'm trying to download Drivers and Firmware for my device but there is 4 files which I can chose from and I don't know if I need them all. should I download all of them? because there is no much difference between them they are named : Win10_18362_20.081.14036.0.msi...
  9. Wireless Display Adapters Firmware Issue
    Wireless Display Adapters Firmware Issue: I am hearing that it is not a good idea to update the firmware on the wireless display adapters ... is this true??? https://answers.microsoft.com/en-us/windows/forum/all/wireless-display-adapters-firmware-issue/d30f660e-ee09-44e8-9b55-0c479f4d04dc
  10. How to downgrade the firmware of the Wireless Display Adapter
    How to downgrade the firmware of the Wireless Display Adapter: Hello, We have two Microsoft Wireless Display Adapters and one of the firmware version is V.2.0.8350. and another one is V.2.8381 But the higher version Adapter cannot display very well, always cannot display completely. And the lower version one is working well. Could...
