Windows 10: Edge keeps using GPU 1 even after forcing power-saving graphics performance
Discus and support Edge keeps using GPU 1 even after forcing power-saving graphics performance in Windows 10 Ask Insider to solve the problem; Version: 83.0.478.37 (Official build) (64-bit) on W10 1909 Edge keeps using GPU and it makes things worse when the laptop is unplugged. From Graphics... Discussion in 'Windows 10 Ask Insider' started by /u/thesereneknight, May 31, 2020.
Edge keeps using GPU 1 even after forcing power-saving graphics performance - Similar Threads - Edge keeps using
change gpu used in power saving mode
in Windows 10 Gamingchange gpu used in power saving mode: Is it possible to change what gpu is used when power saving mode is on? https://answers.microsoft.com/en-us/windows/forum/all/change-gpu-used-in-power-saving-mode/4730853b-6328-4b85-9221-4fc5e747e4cb -
in Windows 10 Software and Appschange gpu used in power saving mode: Is it possible to change what gpu is used when power saving mode is on? https://answers.microsoft.com/en-us/windows/forum/all/change-gpu-used-in-power-saving-mode/4730853b-6328-4b85-9221-4fc5e747e4cb -
Forced to use Edge
in Windows 10 GamingForced to use Edge: I use IE Explorer for a few specific things. I understand it will no longer be supported and updated, I am perfectly fine with that.What I am NOT fine with however, is the idea that you software developers seem to have that, if we the CUSTOMER buys your software and install... -
Forced to use Edge
in Windows 10 Software and AppsForced to use Edge: I use IE Explorer for a few specific things. I understand it will no longer be supported and updated, I am perfectly fine with that.What I am NOT fine with however, is the idea that you software developers seem to have that, if we the CUSTOMER buys your software and install... -
Forced to use Edge
in Windows 10 Network and SharingForced to use Edge: I use IE Explorer for a few specific things. I understand it will no longer be supported and updated, I am perfectly fine with that.What I am NOT fine with however, is the idea that you software developers seem to have that, if we the CUSTOMER buys your software and install... -
Game Not Using High Performance GPU Despite Graphics Settings
in Windows 10 GamingGame Not Using High Performance GPU Despite Graphics Settings: I'm trying to run a game Minecraft Java Edition with the high performance GPU in my laptop instead of the integrated GPU, but no matter what settings I change it still runs on the iGPU. What I've tried: Changing "Graphics performance preference" for the Minecraft... -
Power Saving Gpu and High Performance gpu are same Showing Intel r HD graphics in Both
in Windows 10 Drivers and HardwarePower Saving Gpu and High Performance gpu are same Showing Intel r HD graphics in Both: have 2 Gpus Intel r HD graphics and Nvidia 310m but there it is showing only Intel r Hd graphics in both power saving and high performance gpu. I have added those application I want to run in nvidia control panel to use nvidia gpu but when i open them it still lag and i dont... -
How to manually set "power saving gpu" and "high performance gpu" on Windows 10
in Windows 10 Drivers and HardwareHow to manually set "power saving gpu" and "high performance gpu" on Windows 10: While I have both these cards in my system: NVIDIA GeForce GTX 670 NVIDIA GeForce RTX 2060 SUPER Windows only gives me the option to use the weakest one. I've searched the whole world for a solution, unfortunately without success. Any idea? Thanks in advance.... -
Only power saving GPU available in Windows 10 Graphics Settings
in Windows 10 Drivers and HardwareOnly power saving GPU available in Windows 10 Graphics Settings: My laptop has two GPUs connected to it. Intel HD Graphics 3000 and Nvidia NVS 4200. All my Windows Store apps use the Intel GPU but I would want them to use the Nvidia one, so I go to Settings > System > Display > Graphics Settings, then I select a Universal App and click...
