Windows 10: Edge problem on Desktop but OK on Surface Pro
Discus and support Edge problem on Desktop but OK on Surface Pro in Windows 10 Software and Apps to solve the problem; This morning when I started my desktop computer and Edge started there was a sidebar. I closed the sidebar and opened a website and parts of it was... Discussion in 'Windows 10 Software and Apps' started by AirForce9797, Oct 5, 2022.
  1. Edge problem on Desktop but OK on Surface Pro
    This morning when I started my desktop computer and Edge started there was a sidebar. I closed the sidebar and opened a website and parts of it was missing. When I opened the Microsoft website it looked like this:It looks ok on my surface pro.
  2. Problem updating Windows Surface Pro 4 with Windows 10 feature updates
    I have manage to install image for Microsoft Surface Pro 4 by going to https://support.microsoft.com/en-us/...erecoveryimage and download a recovery image for Microsoft Surface Pro 4.
    What I did to reset your Surface from a USB recovery drive was:
    Step 1: Make sure your Surface is turned off and plugged in (hold down the power
    button for 30 seconds).
    Step 2: Insert the USB recovery drive into the USB port on your Surface.
    Step 3: Press and hold the volume-down button while you press and release the
    power button on your Surface.
    Step 4: When the Surface logo appears, release the volume button.
    Step 5: When prompted, select the language and keyboard layout you want.
    Step 6: Select Troubleshoot > Reset your PC.
    If prompted for a recovery key, select Skip this drive at the bottom of the
    screen.
    Step 7: Select the target operating system you wish to reset. This
    refers to the current operating system installed on your Surface.
    Step 8: Select Yes, repartition the drives, and on the next page, select Next.
    Step 9: Choose Just remove my files.
    Step 10: Select Reset.
    Surface restarts and the Surface logo displays while the reset process continues
    (this can take a while).
    This always fails and I have to do the below which continues installation.
    Windows 10 Installation Media:
    1. Insert the Media (DVD/USB) in your PC and restart.
    2. Boot from the media.
    3. Select Repair Your Computer.
    Select Troubleshoot.
    1. Choose Command Prompt from the menu:
    Type in the command:
    Diskpart
    List disk (Note which disk is your Boot drive number mine is 0)
    Sel disk 0
    List vol (Note which volume is the EFI partition mine is 4)
    Sel vol 4
    assign letter=V:
    Exit
    V:
    After you have assigned a drive letter Using Diskpart You can format the EFI partition:
    Example: if you assigned a letter V to the partition the command would be:
    format V: /FS:FAT32
    bcdboot C:\windows /s V: /f UEFI
    Now I have an issue that I cannot install Feature Updates. They keep failing to install.
    Any ideas how to resolve issue?
    jaburmester, Oct 5, 2022
  3. Roohi_Taj Win User
    Surface Pro 3
    Hi ChrisWaters3,
    Could you please help me with the below information:
    1. Does the battery drain out, if the tablet is not connected to peripherals?
    2. Which version of Windows you are using? (To check, type: winver in start menu and hit enter.)
    I understand how something like this can try your patience. This issue is an indication of faulty drivers or incompatible driver.
    However, I suggest you to follow the troubleshooting steps mentioned below:
    Method 1: Check the drivers.
    Step1: Battery driver
    1. Press Windows andR
      key together on your Keyboard.
    2. Type devmgmt.msc and hit enter.
    3. Click on view on top > Select Show hidden devices.
    4. Expand the Batteries option from the list.
    5. Select the ACPI Compliant Control Method Battery> right click on the driver and click on
      Properties.
    6. Click on Driver tab > check if you have the option to
      Roll Back Driver.
    7. If yes, Roll back the driver or uninstall it and restart the computer.
    Uninstalling the driver will be automatically installed after the system is restarted. Check if the issue is fixed.
    Step 2: Keyboard driver.
    1. In the Device manager, go to ‘Other devices’, you will find
      Unknown devices.
    2. Double tap on the unknown device > click on
      Driver tab> click on update driver.
    3. Select browse my computer for driver software> Click on Let me pick from a list of device drivers
    4. Select keyboard, then click ‘Next’.
    5. Select HID Keyboard device and click finish.
    Method 2: Run the toolkit.
    Note: If your Surface is managed by your work or school, check with your organization's IT department before running the tool.
    I would suggest you to run the toolkit provided by Microsoft on
    Fix common Surface
    problems using the Surface Diagnostic Toolkit
    If the above steps, doesn’t fix the issue. I would suggest you to follow the steps mentioned in the article on
    Surface Pro 3 Battery
    FAQ for the Surface Pro Embedded Controller Firmware update
    Hope it helps.
    Roohi Taj S
    Roohi_Taj, Oct 5, 2022
  4. Roger Win User
    MS Surface Keyboard Cover not recognized by MS Surface Pro 3
    My Surface Pro 3 cover mysteriously stopped working (other USB keyboards work).
    I’ve exhausted all of the steps from the Internet and am hoping for some advice here on what to try next.
    • Clean the metal pins on both the keyboard and the Surface Pro 3 with alcohol swap and q-tip.
    • Performed the standard two button shutdown procedure - Force a shutdown and restart your Surface
    • Update "HID keyboard" device in Device Manager.
    • Uninstall and reinstall "HID keyboard device" in Device Manager.
    • Removed HID keyboard device in Device Driver and manually installed Surface Type Cover device (which later automatically turns to "HID keyboard device" when you hit "update drivers")
    • Updated all Windows 10 patches to date.
    • Tried a brand new keyboard (Microsoft FMM-00001 Type Cover for Surface Pro https://www.amazon.com/gp/product/B073W4MPJF/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 )
    • Updated firmware for Surface Pro 3 (typed in “winver”, took that Windows version, then downloaded the specific patch required here - https://www.microsoft.com/en-us/download/details.aspx?id=38826)
    • Reset Surface Pro 3 while keeping personal files
    • Reset Surface Pro 3 and deleted all personal files
    • Performed hardware tests on aka.ms/surfacerepair (nothing bad found; all looks ok)
    • Drained the battery most of the way before connecting again - the two times it worked momentarily these last few days was when I connected my new type cover keyboard to the Surface Pro 3 after the battery had died down to below 50%; a simple reboot later, everything stopped working. This user seems to have the same problem with it working briefly when there is low battery - https://answers.microsoft.com/en-us...pe-cover/52f983c6-2e53-49fa-aac6-7c4cc5d25d9f )
    A breakdown of the steps I've done to sometimes get it working
    Can anyone recommend any other troubleshooting steps? One of these steps seemed to work ok for others having this same problem.
    Roger, Oct 5, 2022
  1. Edge problem on Desktop but OK on Surface Pro - Similar Threads - Edge problem Desktop
  2. Edge problem on Desktop but OK on Surface Pro
    Edge problem on Desktop but OK on Surface Pro: This morning when I started my desktop computer and Edge started there was a sidebar. I closed the sidebar and opened a website and parts of it was missing. When I opened the Microsoft website it looked like this:It looks ok on my surface pro....
  3. Surface Pro 7 touch problems with Edge and Chrome
    Surface Pro 7 touch problems with Edge and Chrome: I just bought a Surface 7 and had a 4 for years without problem. It came with Windows 10. I realized that when using websites on Edge or Chrome especially Reddit, scrolling would stop abruptly and it'd take a couple seconds to start working again. Same for clicking on links....
  4. Surface Pro 7 touch problems with Edge and Chrome
  5. Surface Pro connection problem
    Surface Pro connection problem: My surface Pro is not connecting to the internet or showing any connections. Diagnostic check states "Possible problem with wi-fi adaptor" which the fix did not resolve. Thanks in anticipation....
  6. Surface Pro Problems
    Surface Pro Problems: Recently my surface pro 4 has been blue screen crashing with the pdc-sys-watchdog error. It's a program that's not responding and timing out on startup, I have tried updating all my drivers through the device manager window. I now have reason to believe it may be sticky notes...
  7. disable edge swipe on surface pro 1796 (surface pro 4-ish)
    disable edge swipe on surface pro 1796 (surface pro 4-ish): Cannot even find out if I have a surface pro 3 or 4, only info is: BaseBoard Version Not Available System SKU Surface_Pro_1796 Version 10.0.18362 Build 18362 OS Name Microsoft Windows 10 Pro After intensive search on the internet I found three "solutions" to disabling...
  8. Surface Pro and lightroom problem
    Surface Pro and lightroom problem: HI I am trying to use Adobe lightroom on the surface pro to do tethered shooting. Each time I connect the camera to the surface pro lightroom cannot find the camera ?? This fault does not show up on my main windows laptop so am guessing there is a problem with the pro...
  9. Surface Pro 4 Desktop
    Surface Pro 4 Desktop: My desktop shortcuts have disappeared, what happened? https://answers.microsoft.com/en-us/windows/forum/windows_10-start-win_desk/surface-pro-4-desktop/185da481-c6fa-49b5-be88-d3d7cf7c38fb
  10. surface pro 4 cortana and skype - microphone problem, google chrome web - microphone is OK
    surface pro 4 cortana and skype - microphone problem, google chrome web - microphone is OK: Hello, I have Surface Pro 4 . After update win 1803 and set up privacy access of microphone to all apps. Here are the results: surface pro 4 cortana - can not hear me at all. skype - microphone not work at all also. microsoft microphone app - record my voice and microphone...
