Windows 10: Explorer.exe stuck in "Class not registered" loop, no metro apps opening, no sound, MMC not...
Discus and support Explorer.exe stuck in "Class not registered" loop, no metro apps opening, no sound, MMC not... in Windows 10 BSOD Crashes and Debugging to solve the problem; When I started my Windows 10 computer, after failing to update stuck at 7% 1 of 3, I unplugged, and it tried to undo and restarteD, a few things are... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by BrandonSky, Jan 14, 2021 at 12:07 PM.
Explorer.exe stuck in "Class not registered" loop, no metro apps opening, no sound, MMC not... - Similar Threads - Explorer exe stuck
class not registered
in Windows 10 Installation and Upgradeclass not registered: Neither Edge or the start menu will load on my computer. It just comes up with X class not registered. Any suggestions? https://answers.microsoft.com/en-us/windows/forum/all/class-not-registered/b89d2a6e-15e3-4de5-93bc-8df3d8af611f -
in Windows 10 Installation and UpgradeClass not registered: I am having multiple issues with my computer.. My start menu isnt working, all UWP apps dont work, and windows store doesnt work. When I try to launch for instance: Photos, it comes up with an error box with a title of: explorer.exe, and it says Class not registered.. That... -
“Class not Registered”?
in Windows 10 Customization“Class not Registered”?: Somehow lost my Windows and Explorer coming up “Class not Registered” cant open Start , how do i fix? https://answers.microsoft.com/en-us/windows/forum/all/class-not-registered/e28f2d58-9c7d-4b21-ab7e-218b6077f39d -
cannot open start button and Explorer says class not registered
in Windows 10 Customizationcannot open start button and Explorer says class not registered: Windows 10 cannot open start button and Explorer says class not registered https://answers.microsoft.com/en-us/windows/forum/windows_10-start/cannot-open-start-button-and-explorer-says-class/d9d20054-d711-4e6c-af01-ba4aeceb1c7b -
Class Not Registered Error
in Windows 10 SupportClass Not Registered Error: Every time I try to open my steam game a get this error Imgur. I have a newly installed version of windows 10. 83870 -
Windows Search: Class not registered
in Windows 10 SupportWindows Search: Class not registered: Windows Search stopped working. The event log shows the entry: The Windows Search service terminated with the following service-specific error: Class not registered If I attempt to start the service manually, a MessageBox pops up and tells me to check the Event... -
in Windows 10 Support"Class not registered": I get this error message every time I click on a link. How do I fix it. Thanks for your help. 46143 -
Explorer.exe Class Not Registered
in Windows 10 SupportExplorer.exe Class Not Registered: I am running windows 10 x64, version 16299.64. On my standard local user account which I do not use often is the problem maker.......All the ModernApps and the Start Menu do not work..........A box with title 'Explorer.exe' and message "Class Not Registered" pops out....... -
"Class not registered" problem
in Windows 10 Support"Class not registered" problem: Hello, Each time I start my pc, get popup notice about some "Class not registered" with some microsoft internet address. The notice attached here. What is it and how to fix it. Answers will be appreciated. Thanks 94329
