Windows 10: Fan and power lights remain turned on after shutting down PC
Discus and support Fan and power lights remain turned on after shutting down PC in Windows 10 Performance & Maintenance to solve the problem; When I turn off my computer, the screen goes back as normal, but the lights remain turned on and the fan doesn't stop. If I hold down the power... Discussion in 'Windows 10 Performance & Maintenance' started by FZs.111, Oct 28, 2019.
Fan and power lights remain turned on after shutting down PC - Similar Threads - Fan power lights
Why do the power light and airplane mode light remain on after shutting down the ASUS TUF...
in Windows 10 GamingWhy do the power light and airplane mode light remain on after shutting down the ASUS TUF...: Why do the power light and airplane mode light remain on after shutting down the ASUS TUF Gaming F15 FX507ZC4 laptop? https://answers.microsoft.com/en-us/windows/forum/all/why-do-the-power-light-and-airplane-mode-light/73517b81-3c13-40d6-b3cf-865e4d8a0550 -
in Windows 10 Software and AppsWhy do the power light and airplane mode light remain on after shutting down the ASUS TUF...: Why do the power light and airplane mode light remain on after shutting down the ASUS TUF Gaming F15 FX507ZC4 laptop? https://answers.microsoft.com/en-us/windows/forum/all/why-do-the-power-light-and-airplane-mode-light/73517b81-3c13-40d6-b3cf-865e4d8a0550 -
After computer shut down, fans and lights are still on and running
in Windows 10 GamingAfter computer shut down, fans and lights are still on and running: HI, Recently, my computer no longer completely shuts down after using the Windows Start Menu / Power / Shut Down option. Windows shuts down, the screen goes blank but the computer stays on i.e. power light is on and fans are running. Here's what I've done so far to try to... -
in Windows 10 Software and AppsAfter computer shut down, fans and lights are still on and running: HI, Recently, my computer no longer completely shuts down after using the Windows Start Menu / Power / Shut Down option. Windows shuts down, the screen goes blank but the computer stays on i.e. power light is on and fans are running. Here's what I've done so far to try to... -
Power Light remains on after turning off zenbook - windows11
in Windows 10 GamingPower Light remains on after turning off zenbook - windows11: Help! Recently had trouble with bitlocker encryption turning itself on. Managed to fix this but now I'm presented with a PC I can't properly turn off. I've checked for driver updates. I've run troubleshooter. I've disabled quick start up. No success. The PC appears to go into... -
Pc fans and lights still on after shut down
in Windows 10 Performance & MaintenancePc fans and lights still on after shut down: Hi So I am having a problem with my pc where when i shut it down my fans and lights are still on and the only thing I am able to do is hold down my power button till it turns off.... -
power problem laptop won't turn on after sleep or shut down lights power light stays on
in Windows 10 Performance & Maintenancepower problem laptop won't turn on after sleep or shut down lights power light stays on: power lite and power button lite stay on after shutdown but windows doesn't shut down all the way. I have to press the reset button to get it going again I dont know what.s going on with this . HELP!!!... -
Computer keeps shutting down but remains on (fans/lights all running)
in Windows 10 BSOD Crashes and DebuggingComputer keeps shutting down but remains on (fans/lights all running): Hello, I've tried literally everything I can think of so I'm hoping someone can help me. My computer recently started shutting down while in sleep mode, or more becoming unresponsive. I'd come back and tap the keyboard to wake the screen and nothing happened. The computer... -
Mouse light is turn on after shut down :/
in Windows 10 CustomizationMouse light is turn on after shut down :/: Hello. Can you please help me to solve this problem. Mouse light is turn on after shut down. I have one solution. If I turn off FAST STARTUP,mouse light is turn off but then my pc turn on slower. Do you know another solution where I am not going to take damage on startup...
how to fix pc turned off but fan still on
