Windows 10: Favorites and Edge problem
Discus and support Favorites and Edge problem in Browsers and Email to solve the problem; Why is it that in Edge I have to click a favorites folder twice before the dropdown menu shows? Thanks in advance. 86524 Discussion in 'Browsers and Email' started by Tony Vella, Jun 10, 2017.
Favorites and Edge problem - Similar Threads - Favorites Edge problem
favorites on Edge
in Windows 10 Software and Appsfavorites on Edge: Can I make Edge openwith a verticcal favorites list similar to the way IE has been doing mit? https://answers.microsoft.com/en-us/windows/forum/all/favorites-on-edge/d2a18a59-581e-4e1b-9e51-6f64a533d3c3 -
Edge Favorites
in Windows 10 BSOD Crashes and DebuggingEdge Favorites: Suddenly I'm unable to right click on a link in my favorites folder and have it open in a new window, which I used to be able to do. Now when I click on open in new window, nothing happens. If I click open in a new tab, it does and also when I right click on links in various... -
EDGE Favorites
in Windows 10 CustomizationEDGE Favorites: How do you SORT the favorites? Thanks https://answers.microsoft.com/en-us/windows/forum/all/edge-favorites/05bcaa2d-4440-450c-8012-506287f63127 -
Edge Favorites
in Windows 10 SupportEdge Favorites: I don't usually use Edge, I like IE11; but I've had to dabble in Edge from time to time. I was wondering, where are the Favorites saved? I looked up & found an article that instructed to go to:... -
Edge Favorites
in Windows 10 CustomizationEdge Favorites: How do you change the width of the Favorites Side panel? https://answers.microsoft.com/en-us/windows/forum/windows_10-other_settings/edge-favorites/7d3ac0b7-4fb5-4364-a313-2804ea3e431f -
favorites edge
in Browsers and Emailfavorites edge: Hi Normaly when i do a reinstall of windows i've got my favorits of edage automaticly back But nu not why ? 97290 -
Edge Favorites
in Browsers and EmailEdge Favorites: I too would like to access my W10 Edge Favorites list to edit them. But I find it incredible that no-one (including Microsoft) appears to know where they. I did come across one reply in the Windows 10 forum that listed them but not in the folders in the drop-down list in Edge... -
Edge Favorites.
in Browsers and EmailEdge Favorites.: I just noticed after doing a clean install of windows 10 1607, that my favorites in ms edge are gone. Is there anyway to get them back? Henry 58963 -
Edge Favorites - problem deleting favorites
in Browsers and EmailEdge Favorites - problem deleting favorites: I have not been able to delete favorites from the "Favorite Bar" drop down list. The right-click and the delete key do not work. 12199
