Windows 10: Fibre Connection Problem
Discus and support Fibre Connection Problem in Windows 10 Network and Sharing to solve the problem; I live in a remote area and recently, when it became available, upgraded to a Fibre Broadband connection from a WiFi connection. Since the upgrade my... Discussion in 'Windows 10 Network and Sharing' started by Kashegan, Jun 8, 2018.
Fibre Connection Problem - Similar Threads - Fibre Connection Problem
Speed stuck at 100Mbps on 1Gb Fibre
in Windows 10 GamingSpeed stuck at 100Mbps on 1Gb Fibre: So I have been trying to fix this for the last week....- I have had 1Gb Fibre installed.- I installed a TP-Link 2.5 Gigabit PCI Express Network Adapter TX201 .Issue-The speed on my Ethernet is showing 100.0Mbps.-Changed Speed and Duplex to 1.0Gbps Full Duplex.-Speed on... -
in Windows 10 Software and AppsSpeed stuck at 100Mbps on 1Gb Fibre: So I have been trying to fix this for the last week....- I have had 1Gb Fibre installed.- I installed a TP-Link 2.5 Gigabit PCI Express Network Adapter TX201 .Issue-The speed on my Ethernet is showing 100.0Mbps.-Changed Speed and Duplex to 1.0Gbps Full Duplex.-Speed on... -
in Windows 10 Network and SharingSpeed stuck at 100Mbps on 1Gb Fibre: So I have been trying to fix this for the last week....- I have had 1Gb Fibre installed.- I installed a TP-Link 2.5 Gigabit PCI Express Network Adapter TX201 .Issue-The speed on my Ethernet is showing 100.0Mbps.-Changed Speed and Duplex to 1.0Gbps Full Duplex.-Speed on... -
64-bit Windows pcs do not connect to my new full fibre broadband?
in Windows 10 Gaming64-bit Windows pcs do not connect to my new full fibre broadband?: I have 2 64-bit Windows 10 pcs, a laptop and a desktop and a new Windows 11 laptop. All three machines worked on my old copper broadband connection. Once I had installed a new full-fibre connection the two 64-bit machines cannot connect to the internet. The diagnostics screen... -
Is fibre broadband a waste of £ for our situation?
in Windows 10 Network and SharingIs fibre broadband a waste of £ for our situation?: My ADSL (copper wire) download speed is 13.2 Mbps (see BT Wholesale Test Result picture), which I feel is enough bandwidth for our situation. We use Netflix which only needs 5 Mbps leaving 8.2 Mbps for one other user (there are only the two of us). We only do web browsing,... -
Monitoring Fibre Connection
in Windows 10 Network and SharingMonitoring Fibre Connection: I am suffering from intermittent, but regular, interruptions to my Broadband supply. The provider says there have been no interruptions in service, which leads me to suspect that the Router may be defective. Is there anything I can place between the Fibre Optic Decoder and... -
What a difference fibre makes!
in Windows 10 Network and SharingWhat a difference fibre makes!: I live in an urban area with dense housing. The estate is huge with thousands of properties, and starting a few months ago, we had Virgin Fibre installed in all the streets. Last Friday, the fibre was extended to the house and a fitter installed the rest inside. I opted for... -
Fibre installation
in AntiVirus, Firewalls and System SecurityFibre installation: Hi Guys, I recently had Vumatel Fibre installed on my property, (residential for home use) only had it for a couple weeks but now when I switch on my PC it tells me: "your computer was unable to start...." "Start up repair is checking yr system for problems." Then... -
Fibre Connection Issues
in Windows 10 SupportFibre Connection Issues: I live in a remote area and recently, when it became available, upgraded to a Fibre Broadband connection from a WiFi connection. Since the upgrade my browsers have had repeated initial failures to connect to websites which I didn't have with the WiFi connection, probelms...
