Windows 10: First time using System Image, need some help/advice..
Discus and support First time using System Image, need some help/advice.. in Windows 10 Ask Insider to solve the problem; So i want to make a System Image from my whole Windows 10 (Software, drivers, documents etc..) So i can easily restore my Windows 10.. But my question... Discussion in 'Windows 10 Ask Insider' started by /u/brent005, Jul 27, 2020.
First time using System Image, need some help/advice.. - Similar Threads - using System Image
Need some help and advice, please and thanks
in Windows 10 Ask InsiderNeed some help and advice, please and thanks: submitted by /u/gowashyourmilk [link] [comments] https://www.reddit.com/r/Windows10/comments/kyrrxd/need_some_help_and_advice_please_and_thanks/ -
First thread, need help big time!
in Microsoft Office and 365First thread, need help big time!: I have office 365 mobile on Android ver.10 cell. I can only get a different "header" to work the first two pages of a book I am writing. After the second header, the text in the headers remains the same. Desktops and tablets have a somewhat different format concerning Header... -
I need some advice?
in AntiVirus, Firewalls and System SecurityI need some advice?: Well, I have been programming a bot for GTA Online for a while now. This allows you to stay online, create single lobbies and mute the GTA window. My question: Can I get in trouble for that, because I basically exploit security holes. Be a bit scared after what happened to... -
Need some help with images
in Windows 10 Ask InsiderNeed some help with images: Basically I’m not artistic at all and was looking for a way to take an image and change the transparency on it so that I can copy it onto a cod emblem I’m streaming my Xbox onto my pc and can see my screen and want to overlay a semi-transparent image so I can copy the lines... -
First time I need to use Macrium restore image questions.
in Windows 10 Backup and RestoreFirst time I need to use Macrium restore image questions.: Hello, so I need to restore an image since I try to update from 1809 to 1909 and it failed twice for me. Now while my system isn't unstable there are some Oddities and just figure it's probably best to restore to a previous image that I did yesterday before attempting to... -
Using a cloned system drive the first time.
in Windows 10 Backup and RestoreUsing a cloned system drive the first time.: I’m using a win10 EUFI computer v1909 with only one hard drive bay. I want a second drive to use if I have serious problems. Normally, it will be stored somewhere. It doesn’t replace periodic backups. I’ll use Macirum Reflect to clone the entire internal drive to another... -
Need Some Graphic Card advice
in Windows 10 Graphic CardsNeed Some Graphic Card advice: My pc's cards fan after 4 years just started making a whinning noise I don't know if I could take it out and grease the fan or not but I would rather just get a new card......Say $100 or less....And I'm not a gamer. My pc is a 2013 HP P-6 2400T / Intel 3.1 CPU / 12 gb's... -
Multiple System Images using Backup & Restore - advice?
in Windows 10 Installation and UpgradeMultiple System Images using Backup & Restore - advice?: I have a requirement for a machine that can easily be reimaged to various versions of Windows (all 32 bit). This PC gets lent out, to be reimaged on return. It is also used as a reference machine for support purposes, so the systems should be 'pure' Microsoft (meaning Backup... -
Help and or advice needed
in Windows 10 SupportHelp and or advice needed: I am running Windows 10. I currently attach a hdmi cable from laptop to tv. Is it possible to stream one thing from laptop onto tv screen and simultaneously surf the net using laptop monitor? Thanks 39170
