Windows 10: Following battery change, battery monitor shows "unknown remaining"
Discus and support Following battery change, battery monitor shows "unknown remaining" in Windows 10 Customization to solve the problem; Following installation of a new battery in my ACER M5-481T-6642 laptop running Win 10 (1903), the battery icon in the task bar has grayed out and... Discussion in 'Windows 10 Customization' started by RichardMillerXC, Aug 21, 2019.
Following battery change, battery monitor shows "unknown remaining" - Similar Threads - Following battery change
Remaining battery time isnt showing
in Windows 10 GamingRemaining battery time isnt showing: can't see the remaining time left on my battery https://answers.microsoft.com/en-us/windows/forum/all/remaining-battery-time-isnt-showing/a2435b66-5fee-4b71-a0bf-e87a56b6c4aa -
in Windows 10 Software and AppsRemaining battery time isnt showing: can't see the remaining time left on my battery https://answers.microsoft.com/en-us/windows/forum/all/remaining-battery-time-isnt-showing/a2435b66-5fee-4b71-a0bf-e87a56b6c4aa -
Battery time remaining does not show.
in Windows 10 GamingBattery time remaining does not show.: Even going to the settings does not show the time remaining. It shows the time to be fully charged only.I have an HP Elitebook x360 1040 G5The system is also fully updated.... -
in Windows 10 Software and AppsBattery time remaining does not show.: Even going to the settings does not show the time remaining. It shows the time to be fully charged only.I have an HP Elitebook x360 1040 G5The system is also fully updated.... -
Unknown time remaining/ battery not detected
in Windows 10 BSOD Crashes and DebuggingUnknown time remaining/ battery not detected: I have been having issues with this pc for two years where the battery is concerned. What I should be using is the replacement battery but it fell into the same issues as the first: 1 while installed and running, the pc would cut after or before an hour had gone regardless... -
Battery showing unknown remaining even after reinstalling the acpi driver
in Windows 10 Ask InsiderBattery showing unknown remaining even after reinstalling the acpi driver: How do I fix submitted by /u/dudepi3 [link] [comments] https://www.reddit.com/r/Windows10/comments/ihw28o/battery_showing_unknown_remaining_even_after/ -
Battery unknown remaining
in Windows 10 BSOD Crashes and DebuggingBattery unknown remaining: About a week ago, my laptop started to stop showing the remaining battery and instead showed "Unknown remaining". It would shut down all of a sudden although I did charge overnight, and was only turned on when I plugged in the charger. However, when it is plugged in it showed... -
Battery not detected (Unknown remaining)
in Windows 10 Drivers and HardwareBattery not detected (Unknown remaining): Good day, I'm having battery problems on my Sager NP8372. First, the battery icon on the taskbar suddenly switches back and forth from the default battery icon to “no battery detected” icon and changes my brightness setting. It just happens intermittently, and I don’t know... -
Battery showing unexpected remaining time
in Windows 10 BSOD Crashes and DebuggingBattery showing unexpected remaining time: Hi, I have purchased Huawei's Matebook x pro from the Microsoft store last week. The battery remaining time sometimes is correct, but is mostly anomalous. The manufacturer boasts a battery run time of 12 hours. Is this a manufacturing issue or an issue of Windows 10? It...
